Lenovo Smart Clock Gen 2 - Grey (Dock not included)
Quicklinx: GS82WS00 Mfr#: ZA970006GB
A daily assistant on your nightstand
Let your Lenovo Smart Clock 2 organize your day with reminders and alarms. Ask questions, check on traffic and weather, listen to news briefings, and more—all from the comfort of your bedroom. Just ask Google. Control up to 50,000 compatible devices with your voice or touch. And because you can toggle the mute button and the clock doesn’t have a camera, your privacy is assured.
Louder, crisper sounds
With improved front-firing speakers, the Smart Clock 2 delivers better, room-filling audio compared to its predecessor. The speakers are expertly tuned for clearer vocals. And you can broadcast to other speakers or smart devices across your home.
Easily see what you need
With its 4" colour touchscreen, the Smart Clock 2 showcases the time, weather, and your family photos with a choice of customizable clock faces. With its soft-touch fabric cover in three great colours, it blends perfectly with any décor.
Kickstart your day, unwind in the evening
Start your day better and keep on top of your tasks and schedule. Ask Google to check your next meeting time or play some music while you prepare for the day. Do more with a single command with the "good night" routine: turn off the lights, lock the doors, and play some relaxing white noise or music for a guided meditation before you go to sleep.
Charge your other devices Dock your Smart Clock 2 and let its wireless charging dock deliver a fast charge to your phone while you sleep. Keep your nighstand clutter-free. If you have a second device, use the dock's USB-A port to charge it simultaneously.
Just the right amount of light
Your Smart Clock 2 is enhanced with a built-in nightlight when docked. The light is just bright enough to illuminate your way without bothering anyone else.
  • Voice-controlled smart clock for your bedside
  • Google Assistant - ask questions, set reminders & more
  • Play music from popular streaming services
  • Control other smart devices in your home
  • Touchscreen for even greater control of your smart hom
  • A daily assistant on your nightstand
    Let your Lenovo Smart Clock 2 organize your day with reminders and alarms. Ask questions, check on traffic and weather, listen to news briefings, and more-all from the comfort of your bedroom. Just ask Google. Control up to 50,000 compatible devices with your voice or touch. And because you can toggle the mute button and the clock doesn't have a camera, your privacy is assured.
  • Louder, crisper sounds
  • Easily see what you need
  • Kickstart your day, unwind in the evening
    Start your day better and keep on top of your tasks and schedule. Ask Google to check your next meeting time or play some music while you prepare for the day. Do more with a single command with the"good night" routine: turn off the lights, lock the doors, and play some relaxing white noise or music for a guided meditation before you go to sleep.
  • Charge your other devices
  • Just the right amount of light
Lenovo Smart Clock 2 - smart display - LCD 4" - wireless
Smart display - LCD 4"
Integrated Memory
Flash - 8 GB
Speaker Type
Active
Continuous Power
3 Watt
Amplifier
Integrated
Display
LCD - 4" - 480 x 800 - touch screen
Wi-Fi, Bluetooth
Intelligent Assistant
Google Assistant built-in - direct
Speaker Details
Speaker - mono - 3 Watt - active
Heather grey
11.348 cm x 7.133 cm x 9.33 cm
298 g
1-year warranty
Integrated Memory
Flash - 8 GB
Light
Night light
Microphone
Far field microphone array
Sensors
G-sensor, L-sensor
Enclosure Colour
Heather grey
Design Features
Soft-touch finishing
Speaker System
Speaker Type
Active
Continuous Power
3 Watt
Amplifier
Integrated
IEEE 802.11a/b/g/n, Bluetooth 4.2
Controls
Volume, mute microphone
Display
LCD - 4" - 480 x 800 - touch screen - anti-glare, LED backlight, IPS technology
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Voice Control
Direct
Speaker System Details
Speaker Details
Driver Details
Speaker: full-range driver - 1.5"
Power Source
AC power adapter
11.348 cm
7.133 cm
9.33 cm
298 g
Limited warranty - replacement - 1 year
