A daily assistant on your nightstand
Let your Lenovo Smart Clock 2 organize your day with reminders and alarms. Ask questions, check on traffic and weather, listen to news briefings, and more—all from the comfort of your bedroom. Just ask Google. Control up to 50,000 compatible devices with your voice or touch. And because you can toggle the mute button and the clock doesn’t have a camera, your privacy is assured.
Louder, crisper sounds
With improved front-firing speakers, the Smart Clock 2 delivers better, room-filling audio compared to its predecessor. The speakers are expertly tuned for clearer vocals. And you can broadcast to other speakers or smart devices across your home.
Easily see what you need
With its 4" colour touchscreen, the Smart Clock 2 showcases the time, weather, and your family photos with a choice of customizable clock faces. With its soft-touch fabric cover in three great colours, it blends perfectly with any décor.
Kickstart your day, unwind in the evening
Start your day better and keep on top of your tasks and schedule. Ask Google to check your next meeting time or play some music while you prepare for the day. Do more with a single command with the "good night" routine: turn off the lights, lock the doors, and play some relaxing white noise or music for a guided meditation before you go to sleep.
Charge your other devices Dock your Smart Clock 2 and let its wireless charging dock deliver a fast charge to your phone while you sleep. Keep your nighstand clutter-free. If you have a second device, use the dock's USB-A port to charge it simultaneously.
Just the right amount of light
Your Smart Clock 2 is enhanced with a built-in nightlight when docked. The light is just bright enough to illuminate your way without bothering anyone else.
- Voice-controlled smart clock for your bedside
- Google Assistant - ask questions, set reminders & more
- Play music from popular streaming services
- Control other smart devices in your home
- Touchscreen for even greater control of your smart hom
Let your Lenovo Smart Clock 2 organize your day with reminders and alarms. Ask questions, check on traffic and weather, listen to news briefings, and more-all from the comfort of your bedroom. Just ask Google. Control up to 50,000 compatible devices with your voice or touch. And because you can toggle the mute button and the clock doesn't have a camera, your privacy is assured. -
With improved front-firing speakers, the Smart Clock 2 delivers better, room-filling audio compared to its predecessor. The speakers are expertly tuned for clearer vocals. And you can broadcast to other speakers or smart devices across your home. -
With its 4" colour touchscreen, the Smart Clock 2 showcases the time, weather, and your family photos with a choice of customizable clock faces. With its soft-touch fabric cover in three great colours, it blends perfectly with any décor. -
Start your day better and keep on top of your tasks and schedule. Ask Google to check your next meeting time or play some music while you prepare for the day. Do more with a single command with the"good night" routine: turn off the lights, lock the doors, and play some relaxing white noise or music for a guided meditation before you go to sleep. -
Dock your Smart Clock 2 and let its wireless charging dock deliver a fast charge to your phone while you sleep. Keep your nighstand clutter-free. If you have a second device, use the dock's USB-A port to charge it simultaneously. -
- Lenovo Smart Clock 2 - smart display - LCD 4" - wireless
- Product Type
- Smart display - LCD 4"
- Integrated Memory
- Flash - 8 GB
- Speaker Type
- Active
- Continuous Power
- 3 Watt
- Amplifier
- Integrated
- Display
- LCD - 4" - 480 x 800 - touch screen
- Wi-Fi, Bluetooth
- Intelligent Assistant
- Google Assistant built-in - direct
- Speaker Details
- Speaker - mono - 3 Watt - active
- Heather grey
- 11.348 cm x 7.133 cm x 9.33 cm
- 298 g
- 1-year warranty
- Product Type
- Integrated Memory
- Flash - 8 GB
- Light
- Night light
- Microphone
- Far field microphone array
- Sensors
- G-sensor, L-sensor
- Enclosure Colour
- Heather grey
- Design Features
- Soft-touch finishing
Speaker System
- Speaker Type
- Active
- Continuous Power
- 3 Watt
- Amplifier
- Integrated
- IEEE 802.11a/b/g/n, Bluetooth 4.2
- Controls
- Volume, mute microphone
- Display
- LCD - 4" - 480 x 800 - touch screen - anti-glare, LED backlight, IPS technology
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Type
- Cloud
- Communications Technology
- Wi-Fi
- Voice Control
- Direct
Speaker System Details
- Speaker Details
- Driver Details
- Speaker: full-range driver - 1.5"
- Power Source
- AC power adapter
- 11.348 cm
- 7.133 cm
- 9.33 cm
- 298 g
- Limited warranty - replacement - 1 year
