Lenovo S510 SFF Core i5-6400 4GB 500GB Windows 10 Pro
Quicklinx: CFCVWS00 Mfr#: 10KY0023UK
  • Core i5
The s510 SFF packs high performance into a small footprint, low cost machine. Advanced wireless with enhanced antenna design, plenty of memory and storage, and a sleek, modern design make this a perfect solution for home or small business.
Product Features
Long battery life
Stop worrying about your battery: wih the Lenovo S510p you can stay unplugged up to 5 hours with the standard 4-cell. Plus Lenovo Energy Manager protects the long-term durability of the battery and uses advanced energy-saving technology to increase time spent between charges.
Enhanced graphics
Intel HD HD Graphics deliver powerful high-def performance. Or choose the optional NVIDIA GeForce discrete graphics processing unit (GPU) for efficiency and speedy performance for your HD videos and photos, immersive 3D movies, and entry level gaming.
AccuType keyboard
The full-sized, island-style keyboard is both comfortable and spill-resistant. Finger-friendly curved keys and ergonomic spacing help ensure typing accuracy. Plus the multitouch touchpad adds convenience and supports gestures for easy scrolling and zoom functions.
Dolby advanced audio
With Dolby Advanced Audio, your built-in stereo speakers deliver greater clarity and consistent tone, while providing a cinematic surround-sound experience. Play your music and video louder without distortion. Plus, customize your audio settings to lock-in your preferred volume level for a more consistent listening experience.
Integrated webcam
The S510p features an integrated 0.3mp webcam, with an optional 720p HD webcam available. The 720p includes face-tracking, which is great for multitasking and staying within the frame for web conferences and online video chats - it's the next best thing to being there in person.
Fast data transfer
Move data quickly between the S510p and other devices with USB 3.0 SuperSpeed - it's up to 10 times faster than previous USB technologies and backwards compatible with USB 2.0.
Simple maintenance
With OneKey Recovery, addressing viruses and other technical difficulties is a snap. It's also easy to back up your system and scan for and kill viruses.
  • Intel Core i processor
    The Intel Core i processor delivers 11% faster performance than the previous generation processor, you'll experience extraordinary productivity.
  • Big power in a small form-factor
    The S510 has been put through over 200 reliability tests including shock, drop and vibrations tests in order to maximize both the life of the system and your ROI.
  • Enhanced security
    An array of security features such as Smart USB Protection, which restricts port access while allowing keyboard and mouse inputs, will provide you with peace of mind.
  • Green and sustainable
    The S510 has earned the green certifications of Energy Star 6.1, GREENGUARD, WEEE, and more. Green certification means decreased power consumption, which translates to lower power costs for your small business.
Lenovo S510 - SFF Core i5 6400 2.7 GHz - 4 GB - HDD 500 GB - UK
Personal computer - SFF
Intel Core i5 (6th Gen) 6400 / 2.7 GHz (up to 3.3 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
10 in 1
Graphics Controller
Intel HD Graphics 530
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
29.5 cm x 32 cm x 9 cm
4.13 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
SFF
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2133 MT/s
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
10 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111GN
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 0 (free) x external
Slots
2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
4 x USB 3.0 (2 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 (2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
TopSeller
Power supply
Power Provided
180 watt
Efficiency
85%
Operating System / Software
OS Provided
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
29.5 cm
32 cm
9 cm
4.13 kg
CFCV C2G 2m USB 2.0 A/B Cable - Black In Stock £4.01
CFCV C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £20.78
CFCV C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.43
