Lenovo S500 SFF Intel Core i7-4790s 8GB 1TB Windows 7 Professional 64-bit
Quicklinx: BXNBWS00 Mfr#: 10HS0037UK
  • Core i7
  • DVD-ROM
  • Microsoft Windows 7 Professional 64-bit Edition
This versatile S500 desktop has an extra small form factor and footprint. Though compact, it delivers amazing performance. An extensive range of ports delivers seamless connectivity while the USB protection technology and Lenovo Bluetooth Lock secure your data.
  • Compact for versatility
    Total versatility results from a smaller footprint and a convenient form factor.
  • Excellent security
    Lenovo USB protection technology allows you to restrict port access while allowing keyboard and mouse inputs. Lenovo Bluetooth Lock means your desktop will automatically lock once you step away.
  • Maximum productivity
    A range of ports ensures connectivity with all the peripherals you need.
Lenovo S500 - SFF - Core i7 4790S 3.2 GHz - 8 GB - HDD 1 TB - UK
Personal computer - small form factor
Intel Core i7 (4th Gen) 4790S / 3.2 GHz (, up to 4 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 16 GB (max) - DDR3L SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD
Card Reader
Graphics Controller
Intel HD Graphics 4600
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
9 cm x 32 cm x 29.5 cm
4.13 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
DVD-ROM DVD
Card Reader
Card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line) , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 M.2 Card , 1 (total) / 1 (free) x PCIe x16 - low-profile
2 x USB 3.0 , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
RoHS, WEEE
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
9 cm
32 cm
29.5 cm
4.13 kg
10 °C
35 °C
20 - 80%
