Lenovo S500 SFF i5-4460 4GB 500GB DVDRW Windows 7 Professional
COMPACT DESIGN FOR SMALLER OFFICES!
Quicklinx: BRFLWS00 Mfr#: 10HS0033UK
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
Please note, monitor not included.
Lenovo S500 is an affordable, versatile desktop is 26% smaller than competitor Small Form Factor models, and with a 15% smaller footprint. Advanced WiFi and an extensive range of ports deliver seamless connectivity while Smart USB Protection and Lenovo™ Bluetooth® Lock secure your data.
Stylish, Space-Saving Design
The design of the S500 is sleek and trendy with its black coloring and red highlights indicating key usability features. And its compact footprint takes up to 15 percent less space than a standard tower unit, leaving you with a cleaner work space.
Enhanced Security
An integrated Kensington lock protects your physical asset in addition to your data.
Green & Sustainable
The S500 has earned the green certifications of Energy Star 6.1, GREENGUARD®, and 180W 85-percent ES PSU. Green certification means decreased power consumption, which translates to lower power costs for your small business.
Noise Reduction
Your S500 will give you better acoustic performance with the Lenovo Thermal Solution Kit, reducing sound levels by nearly 14 percent at full CPU load. Less noise means less distraction, keeping you on-task and more productive.
  • Enhanced storage
    Improved SSD storage technology speeds start-up times and delivers fast response times when using multiple applications.
Lenovo S500 - SFF - Core i5 4460S 2.9 GHz - 4 GB - HDD 500 GB - UK
Personal computer - small form factor
Intel Core i5 (4th Gen) 4460S / 2.9 GHz (, up to 3.4 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 4600
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro) + Windows 10 Pro 64-bit Licence
9 cm x 32 cm x 29.5 cm
4.13 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Clock Speed
2.9 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line) , 1 (total) / 0 (free) x internal 3.5"
Slots
2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 M.2 Card , 1 (total) / 1 (free) x PCIe x16 - low-profile
2 x USB 3.0 , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
RoHS, WEEE
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro 64-bit Licence
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
9 cm
32 cm
29.5 cm
4.13 kg
10 °C
35 °C
20 - 80% (non-condensing)
BRFL C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £12.92
