Please note, monitor not included.
Lenovo S500 is an affordable, versatile desktop is 26% smaller than competitor Small Form Factor models, and with a 15% smaller footprint. Advanced WiFi and an extensive range of ports deliver seamless connectivity while Smart USB Protection and Lenovo™ Bluetooth® Lock secure your data.
Stylish, Space-Saving Design
The design of the S500 is sleek and trendy with its black coloring and red highlights indicating key usability features. And its compact footprint takes up to 15 percent less space than a standard tower unit, leaving you with a cleaner work space.
Enhanced Security
An integrated Kensington lock protects your physical asset in addition to your data.
Green & Sustainable
The S500 has earned the green certifications of Energy Star 6.1, GREENGUARD®, and 180W 85-percent ES PSU. Green certification means decreased power consumption, which translates to lower power costs for your small business.
Noise Reduction
Your S500 will give you better acoustic performance with the Lenovo Thermal Solution Kit, reducing sound levels by nearly 14 percent at full CPU load. Less noise means less distraction, keeping you on-task and more productive.
                Enhanced storageImproved SSD storage technology speeds start-up times and delivers fast response times when using multiple applications.
- Lenovo S500 - SFF - Core i5 4460S 2.9 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i5 (4th Gen) 4460S / 2.9 GHz (, up to 3.4 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 4600
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro) + Windows 10 Pro 64-bit Licence
- 9 cm x 32 cm x 29.5 cm
- 4.13 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line) , 1 (total) / 0 (free) x internal 3.5"
- Slots
- 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 M.2 Card , 1 (total) / 1 (free) x PCIe x16 - low-profile
- 2 x USB 3.0 , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-in , 1 x audio line-out
- Theft/Intrusion Protection
- RoHS, WEEE
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro 64-bit Licence
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 9 cm
- 32 cm
- 29.5 cm
- 4.13 kg
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
|  | C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £17.54 |
|  | C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.42 |
|  | C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £16.94 |
