Lenovo RD430 Patsburg-D Intel Xeon E5-2420 8GB
Quicklinx: 976NWS00 Mfr#: SH2E3UK
  • Xeon
The ThinkServer RD430 offers outstanding power efficiency with exclusive Lenovo SmartGrid technology. These storage-rich, value-oriented dual socket rack servers deliver extensive manageability tools, enormous scalability and fit easily into hybrid network environments.
Choose ThinkServer RD430 when you need world-class power efficiency, proven Xeon performance and a extensive set of standard features. It's ideal for use in retail, education or professional services segments, where you need a powerful, highly scalable 2U rack server at prices easy on your budget. You get all this, along with the legendary Think reliability you trust. RD430 features built-in RAID on every model - your managed networks and user groups enjoy vault-safe data protection and lightning-fast data performance. RD430 offers outstanding remote manageability, an array of network adapter choices and rich I/O. RD430 is a perfect fit for hardware RAID workloads where you rely on robust bandwidth yet with energy efficient design innovation. Its open standards design and IPMI 2.0 compliant protocols ensure worry-free integration into your hybrid network environments. RD430 works with your existing tools, management consoles and storage devices.
  • Highly efficient
    ThinkServers deliver world-class power efficiency - up to 45% more efficient than previous generation servers. Innovative Smart Grid power management provides policy-based, rack-level power management to significantly lower your energy consumption. ENERGY STAR certified choices 80+ Gold-rated power supplies and optional low voltage memory provide trusted efficiency and value.
  • Outstanding value
    ThinkServer delivers the performance and reliability you demand, nicely configured as standard. It's everything you need in a durable, highly manageable server, and nothing you don't. Standard rack features include onboard RAID, rail kits, onboard diagnostics, hot swap support and web enabled remote management. Feature rich performance, right out of the box. That's what makes a ThinkServer Think.
  • Business-critical reliability
    Legendary Think quality resonates in the ThinkServer portfolio - outstanding thermal efficiency, and enterprise-tough design give you confident, highly reliable performance. Redundant power and advanced RAID choices offer ideal protection in demanding 24/7 deployments. Rest easy, ThinkServers are designed for rugged use, with vibration-resistant, shock-proof drive carriers and robust chassis designs.
  • Enterprise-grade manageability
    Management made easy - ThinkServers offer front-side powerful Easy Manage tools for quick monitoring. Common feature set, BIOS and tools across models provides intuitive, easy maintenance.
  • Open standards
    ThinkServers fit anywhere. With industry standard protocols and IPMI 2.0 compliant interfaces you enjoy worry free, easy integration into your existing server networks. Don't be locked into proprietary server choices - ThinkServer RD430 works with the tools you use and rely on. Keep your existing management console and storage preferences.
  • Easy serviceability
    Servicing your ThinkServer is easy, with simple 3-step rack installation. Extensive shared parts between platforms make it simple to service components and make upgrades. And, expert help is available fast when you need it - ThinkServer offers rapid 4-hour service response.
Lenovo ThinkServer RD430 - rack-mountable - AI Ready - Xeon E5-2420 1.9 GHz - 8 GB - no HDD
Server - rack-mountable AI Ready - administrator password, boot without keyboard or mouse, serial port I/O control, USB port control, boot sequence control
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon E5-2420 / 1.9 GHz (, up to 2.4 GHz, (6-core)
Processor Socket
LGA1356 Socket
Processor Main Features
Intel QuickPath Interconnect, Intel Turbo Boost Technology 2
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
8 GB (installed) / 192 GB (max) - DDR3 SDRAM - ECC
Storage Controller
SAS (SATA 6Gb/s / SAS 6Gb/s) - PCIe (ThinkServer RAID 500)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
ASPEED AST2300
1GbE
Power Redundancy
Optional
OS Provided
No operating system
48.24 cm x 73.4 cm x 8.76 cm
26.5 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Server - AI Ready
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Led panel
Server Scalability
2-way
Hot-Swap Bays Qty
12
Processor / Chipset
CPU
Intel Xeon E5-2420
Clock Speed
1.9 GHz
Max Turbo Speed
2.4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA1356 Socket
Chipset Type
Intel C606
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
DDR3 SDRAM - ECC
Effective Memory Speed
1333 MHz
DIMM 240-pin
Slots
12 (Total) / 11 (empty)
Registered, mixing of different types of memory modules is not supported, slots 7 - 12 are available in two-processor configuration only
Configuration Features
1 x 8 GB
RAM Supported
48 GB unbuffered , 192 GB registered , 192 GB - low voltage - registered
Hard Drive
No HDD
Storage Controller
1 x SAS - plug-in card - PCIe
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ASPEED AST2300
Video Interfaces
VGA
Integrated
Ethernet Ports
3 x Gigabit Ethernet
Ethernet Controller
Intel 82574L, Intel I350
Remote Management Controller
Integrated Management Module Standard
Bays
12 (total) / 12 (free) x hot-swap 3.5" x 1/3H
Slots
12 (total) / 11 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile (x4 mode)
6 x USB 2.0 (2 front, 4 rear) , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management , 1 x VGA
Administrator password, boot without keyboard or mouse, serial port I/O control, USB port control, boot sequence control
RoHS
TopSeller
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Gold
Operating System / Software
OS Provided
No operating system
Sustainability Information
ENERGY STAR Certified
48.24 cm
73.4 cm
8.76 cm
26.5 kg
