This sleek and stylish full-size keyboard and mouse combo offers exceptional quality in a modern wireless solution. The slim 3-zone keyboard with number pad has responsive quiet keys and a premium typing experience. One-touch dedicated media keys put the controls you use more at your fingertips. The ergonomic full-size mouse provides comfort and support for all-day use. Complete tasks with ease using the precise laser sensor and 4-way scroll wheel. Connect compatible devices with nano receiver.
Wireless convenience
Experience the freedom of wireless connectivity with a 2.4 GHz interface, eliminating the clutter of cables for a cleaner workspace. The included USB wireless receiver ensures a stable connection for both the keyboard and mouse, offering seamless input and navigation. -
Comfortable design
Designed with adjustable height features, this keyboard provides an ergonomic typing experience, reducing strain during long work sessions. The presence of a numeric keypad further enhances productivity for data entry and financial tasks. -
Broad compatibility
Fully compatible with PC systems, this keyboard and mouse set is ready to plug and play, making it a versatile choice for various computing environments. Its compliance with multiple standards ensures reliability and safety in use.
 - Lenovo Professional Combo - keyboard and mouse set - UK Input Device
 - Keyboard and mouse set
- Interface
 - 2.4 GHz
- Wireless Receiver
 - USB wireless receiver
- Connectivity Technology
 - Wireless
- Localization and Layout
 - UK
- Protection
 - Spill-resistant
- Numeric Keypad
- Pointing Device
 - Mouse - wireless - laser
- Buttons Qty
 - 5
 - 2-year warranty
- Interface
 - 2.4 GHz
- Wireless Receiver
- Dimensions (WxDxH) / Weight
 - Keyboard: 45 cm x 16.4 cm x 2 cm / 700 g , Mouse: 6.4 cm x 11.3 cm x 3.4 cm / 80 g
 - Wireless
 - UK
- Adjustable Height
- Protection
 - Spill-resistant
 - Numeric keypad
Pointing Device
 - Mouse - wireless
- Buttons Qty
 - 5
- Movement Detection Technology
 - Laser
- Movement Resolution
 - 1600 dpi
 - Plug and Play, TUV, VCCI, BSMI, CB, IC, MIC, FCC, NTRA, AES-128, KCC, ANATEL, cTUVus, WPC, SRRC, EAC, CITC, NCC, iDA, RCM, BIS, COFETEL, ICASA, TRA, Subtel, NTC, SIRIM, ETA, CNC, IFETEL, CONATEL, SDPPI
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
 - 20 - 95%
