16" mobile workstation for AI-assisted workflows& professional-level graphics
Enterprise-grade security, manageability& reliability with up to Intel vPro
True mobility, sleek design,& advanced Flex Cooling System for long-term reliability
High-capacity LPCAMM2 memory to run multiple applications simultaneously
Seamless collaborations through boosted connectivity& network capacity.
Looks Good- Performs Even Better
Elevate your work-anywhere experience with the 16? ThinkPad P1 Gen 7- a revolution in mobile workstations with its premium power and sleek, visually stunning design. Perfectly balancing form and function, this system redefines portable performance and ensures readiness to excel in remote work scenarios. -
Unparalleled Power in a Mobile Device
With best-in-class performance, the ThinkPad P1 Gen 7 mobile workstation is our most powerful ThinkPad yet! It boasts Intel Core Ultra processors for advanced computing capabilities and multitasking- it'll handle whatever demanding workloads come your way. -
AI-Assisted Productivity
Equipped with dedicated AI engines on the neural processing unit (NPU) and the optional discrete graphics processing unit (GPU), this mobile workstation is ideal for complex AI workloads, ultra-realistic visuals, and data-intensive tasks. -
Pro-Level Graphics with AI Tensor Cores
Welcome to a new era of AI-performance, speed, and precision in mobile workstations. Slice through complex rendering, high-end 3D visualizations, and animations to transform workflow efficiencies with the optional NVIDIA RTX Ada Generation GPUs. -
Streamline Your IT Operations
With up to Intel vPro technology, this mobile workstation delivers the multilayer security, management, and stability that IT pros love. Safeguard assets from emerging cyber threats, get faster insights on your business, and optimize remote operations. -
Follow Your Pursuits Anywhere
When you're on the go, you need a battery powerful enough to support time in the field without electrical outlets. The P1 Gen 7 boasts a massive battery that's also replaceable, should you ever need to upgrade. Plus, it supports rapid-charging technology, so when you need a charge, simply plug in for 60 minutes and get 80% capacity. -
When Every Pixel Counts
When premium displays really matter, the P1 Gen 7 laptop has you covered. All of your choices include wide-angle views, low blue light to prevent eye strain, and X-Rite factory colour calibration to ensure colour accuracy when you're creating. You can also choose a touchscreen model with millions of pixels for premium visuals. -
Optimal Software Performance
Software and apps run flawlessly on the P1 Gen 7 workstation, which boasts a long list of independent software vendor (ISV)* certifications. Whether you work in Adobe, AutoCAD, Maya or something else, you can trust that we've eliminated compatibility issues and potential crashes, so you'll enjoy great project-output quality without hiccups.*See the complete list of ISV certifications -
Smooth& Efficient
Go ahead- push your device to perform. The ThinkPad P1 Gen 7 mobile workstation offers advanced thermals, including liquid metal cooling on select models, and an innovative Flex Cooling System, a fan-based cooling mechanism. Plus a dual-outlet exhaust system optimizes airflow and keeps your system running efficiently. -
Huge Memory Reserve& Performance Capacity
Compile code faster and streamline app development on the ThinkPad P1 Gen 7 workstation. An industry first, this laptop features customer-replaceable LPCAMM2 memory to align with your evolving needs. It boasts lower latency, better bandwidth, and faster speeds to run multiple applications simultaneously, reducing load times for heavy-duty programs. -
Steadfast Security
Biometrics provide extra protection on the P1 Gen 7 workstation, from the fingerprint reader to facial recognition software. ThinkShield, our comprehensive suite of security solutions, boasts discrete Trusted Platform Module (dTPM) to encrypt critical data. Plus Intel Threat Detection Technology helps prevent ransomware, cryptojacking, and more. -
Energy Efficient
Energy efficiency makes sense. In the short-term, it can lower monthly costs and in the long term, it helps sustain resources in demand. The P1 Gen 7 mobile workstation includes several certifications, including ENERGY STAR 8.0 and TCO 9. -
Relies on Recycled Components
This ThinkPad uses recycled magnesium- 90% and 75% in the keyboard frame and top cover respectively. The bottom cover uses 55% recycled aluminum, while the AC adapter uses 30% post-consumer content (PCC) recycled plastic. Plus, packaging is plastic-free! -
ThinkPad Reliability
Even with its efficiency and recycled materials, you can count on the P1 Gen 7 for durability. With MIL-STD-810H certification, it meets or exceeds 12 standards, 26 procedures, and 200+ quality checks ensure that these devices run in extreme conditions.
 - Lenovo ThinkPad P1 Gen 7 - AI Ready - 16" - Intel Core Ultra 7 - 165H - Intel Evo vPro Enterprise Platform - 32 GB RAM - 1 TB SSD - UK
- Product Type
 - Mobile workstation - AI Ready
- Operating System
 - Win 11 Pro - English
- Platform Technology
- Processor
 - Intel Core Ultra 7 (Series 1) - 165H / 1.4 GHz, up to 5 GHz / 24 MB Cache
- Neural Processor Unit (NPU)
 - Intel AI Boost
- Memory
 - 32 GB LPDDR5X (1 x 32 GB)
- Storage
 - 1 TB SSD - TCG Opal Encryption 2, NVMe, Performance
- Display
 - 16" 2560 x 1600 / WQXGA @ 165 Hz
- Graphics
 - NVIDIA GeForce RTX 4070 / Intel Arc Graphics
- Video Memory
 - 8 GB GDDR6 SDRAM
- Input Device
 - Keyboard, TrackPoint, UltraNav
- Keyboard
 - UK
- Keyboard Backlight
- Integrated Webcam
- Networking
 - 802.11a/b/g/n/ac/ax/be, Bluetooth 5.4
- Security
 - Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
 - Black
 - 35.44 cm x 24.12 cm x 1.705 cm
 - 1.82 kg
- Localisation
- Manufacturer Selling Program
 - Lenovo TopSeller
- Environmental Standards
 - TCO Certified Notebooks 9, TCO Certified, generation 10, for notebooks, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
 - 272 kg carbon emissions
 - Base warranty - 3 years - pick-up and return , Base warranty - battery - 1 year , Extended warranty - 3 years - on-site - response time: next business day
- Bundled Services
 - 3 Years Lenovo Premier Support, CO2 Offset 0.5 ton (2nd Gen)
- Product Type
- Operating System
 - Windows 11 Pro - English
Processor / Chipset
- CPU
 - Intel Core Ultra 7 (Series 1) 165H / 1.4 GHz
- Max Turbo Speed
 - 5 GHz
- Number of Cores
 - 16-core
- Cache
 - 24 MB
 - Integrated memory controller
 - Intel AI Boost
- RAM
 - 32 GB (1 x 32 GB)
- Max RAM Supported
 - 64 GB
- Technology
 - LPDDR5X SDRAM
- Speed
 - 7467 MHz
- Rated Speed
 - 3734 MHz
- Form Factor
 - LPCAMM2
- Slots Qty
 - 1
- Empty Slots
 - 0
Storage
- Main Storage
 - 1 TB SSD M.2 2280 PCIe 4.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe), Performance
- RAID Level
 - RAID 0, RAID 1
Display
 - 16" - IPS
- Resolution
 - 2560 x 1600 (WQXGA)
- V-Sync Rate at Max Res.
 - 165 Hz
- Widescreen
- Image Aspect Ratio
 - 16:10
- Image Brightness
 - 500 cd/m²
- Horizontal Viewing Angle
 - +89 / -89
- Vertical Viewing Angle
 - +89 / -89
- Colour Gamut
 - 100% sRGB
 - Anti-glare, Low Blue Light technology, DC dimming, X-Rite factory colour calibration, 91.7% screen-to-body ratio
Audio & Video
- Multi-GPU Configuration
 - 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
 - 8 GB GDDR6 SDRAM
- Max Monitors Supported
 - 3 external monitor(s)
- Video System Features
 - Advanced Optimus, Dynamic Boost 2.0, Direct X 12 Ultimate
- Camera
- Resolution
 - 5 Megapixel
- Camera Features
 - Privacy shutter, IR camera, Windows Hello, fixed focus, Ultrasonic Human Presence Detection
- Sound
 - Stereo speakers, dual array microphone
- Codec
 - Realtek ALC3306
 - High Definition Audio, Dolby Atmos
- Audio Features
 - Input: Dolby Voice, far-field
Input
- Keyboard Layout
 - UK
 - Spill-resistant, multi-touch touchpad, glass touchpad, haptic touchpad
Communications
- Wireless
- Wireless Controller
 - Intel WI-FI 7 BE200
 - Dual stream (2x2)
- Technology
 - Lithium polymer
- Capacity
 - 90 Wh
AC Adapter
- Input
 - AC 100-240 V (50/60 Hz)
- Output
 - 170 Watt
Connections & Expansion
- Slots
 - 2 x M.2 (PCI Express 4.0 x4) (1 free)
- Interfaces Details
 - USB 3.2 Gen 1 (Always On) , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , 2 x USB4 (supports Thunderbolt 4, DisplayPort 2.1 Alt Mode) (Power Delivery 3.0) , HDMI (8K support) , Headphone/microphone combo jack
- Memory Card Reader
 - Yes (SD Express Card)
Software
- Software Included
 - Intel Connectivity Performance Suite
 - Black
- Case Material
 - Aluminium (top), aluminium (bottom)
- Security
 - Administrator password, power-on password, RapidCharge, MIL-STD-810H tested, self-healing BIOS, NVMe password, bottom cover tamper detection
- Theft/Intrusion Protection
- Security Slot Type
 - Kensington nano security slot
- Included Accessories
 - Power adapter
 - RoHS, FIPS 140-2, TUV Rheinland Low Blue Light Certification, TCG Certified
- Localization
 - Lenovo TopSeller
 - 1.82 kg
Sustainability Information
- TCO Certified
 - - TCO Certified Notebooks 9, TCO Certified, generation 10, for notebooks
- EPEAT Compliant
 - EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
 - 46
- PAIA Version
 - 1.4.0
- Packaging Recycled Content
 - 90 % - plastic-free, recycled and/or FSC certified
- Bundled Services
 - 5 °C
 - 35 °C
 - 8 - 95%
Essential Accessories (12)
Get more from your purchase from one of our essential accessories
                        Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £192.81 |
                        Lenovo ThinkPad Basic Topload - Notebook carrying case - 15 | In Stock | £13.44 |
                        Lenovo ThinkPad Universal USB-C Dock UK | In Stock | £141.26 |
                        Lenovo ThinkPad Thunderbolt 4 Workstation Dock - UK/HK/SGP/MYS | In Stock | £312.73 |
                        Lenovo Thinkpad 170W Slim AC Adaptor | In Stock | £54.14 |
                        Lenovo ThinkPad Universal Thunderbolt 4 Dock | In Stock | £250.42 |
                        Lenovo Casual Toploader T210 - Notebook carrying case 15.6" Black | In Stock | £15.54 |
                        Lenovo ThinkPad Universal Thunderbolt 4 Smart Dock | In Stock | £302.48 |
                        Lenovo TP ESSENTIAL CASE 16-INCH BACKPACK | In Stock | £29.45 |
                        Lenovo LThinkPad Universal USB-C Dock - Docking station - USB-C - H | In Stock | £150.53 |
                        Lenovo ThinkPad Essential 16 INCH Topload (Eco) | In Stock | £25.92 |
                        Lenovo LENOVO USB-C SLIM TRAVEL DOCK | In Stock | £50.62 |
Other bundles (16)
                        Lenovo HDMI to VGA Monitor Adapter | In Stock | £22.97 |
                        Lenovo 2m HDMI Cable | In Stock | £16.94 |
                        Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £27.09 |
                        Lenovo Professional Wireless Keyboard | In Stock | £52.98 |
                        Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.01 |
                        Lenovo Essential Compact Wireless Mouse | In Stock | £13.76 |
                        Lenovo USB-C To USB-C Cable - 2m | In Stock | £31.47 |
                        Lenovo Hybrid USB-C to USB-C Cable with USB-A Adaptor 1m | In Stock | £23.23 |
                        Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.78 |
                        Lenovo Stereo 3.5mm Headset | In Stock | £18.05 |
                        Lenovo USB-C Cable 1M | In Stock | £15.73 |
                        Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £52.48 |
                        Lenovo ThinkPad Essential Wireless Mouse | In Stock | £13.44 |
                        Lenovo Lenovo Professional Wireless Rechargeable Keyboard and Mouse | In Stock | £58.99 |
                        Lenovo Lenovo Essential Wired Combo - Keyboard and mouse set - USB | In Stock | £20.02 |
                        Lenovo Lenovo - Headset - on-ear - Bluetooth - wireless - USB-A via | In Stock | £69.39 |
