Lenovo P1 G7 UL7 165H 32GB 1TB RTX4070 W11P
Quicklinx: HTR2WS00 Mfr#: 21KV0023UK
Screen Size: 16in
Processor Model: 165H
Operating System: Windows 11 Pro
Hard Drive Capacity: 1TB
Graphics: NVIDIA GeForce RTX 4070 / Intel Arc Graphics
  • IEEE 802.11n
£1,949.85 ex VAT
£2,339.82 inc VAT
16" mobile workstation for AI-assisted workflows& professional-level graphics
Enterprise-grade security, manageability& reliability with up to Intel vPro
True mobility, sleek design,& advanced Flex Cooling System for long-term reliability
High-capacity LPCAMM2 memory to run multiple applications simultaneously
Seamless collaborations through boosted connectivity& network capacity.
  • Looks Good- Performs Even Better
    Elevate your work-anywhere experience with the 16? ThinkPad P1 Gen 7- a revolution in mobile workstations with its premium power and sleek, visually stunning design. Perfectly balancing form and function, this system redefines portable performance and ensures readiness to excel in remote work scenarios.
  • Unparalleled Power in a Mobile Device
    With best-in-class performance, the ThinkPad P1 Gen 7 mobile workstation is our most powerful ThinkPad yet! It boasts Intel Core Ultra processors for advanced computing capabilities and multitasking- it'll handle whatever demanding workloads come your way.
  • AI-Assisted Productivity
    Equipped with dedicated AI engines on the neural processing unit (NPU) and the optional discrete graphics processing unit (GPU), this mobile workstation is ideal for complex AI workloads, ultra-realistic visuals, and data-intensive tasks.
  • Pro-Level Graphics with AI Tensor Cores
    Welcome to a new era of AI-performance, speed, and precision in mobile workstations. Slice through complex rendering, high-end 3D visualizations, and animations to transform workflow efficiencies with the optional NVIDIA RTX Ada Generation GPUs.
  • Streamline Your IT Operations
    With up to Intel vPro technology, this mobile workstation delivers the multilayer security, management, and stability that IT pros love. Safeguard assets from emerging cyber threats, get faster insights on your business, and optimize remote operations.
  • Follow Your Pursuits Anywhere
    When you're on the go, you need a battery powerful enough to support time in the field without electrical outlets. The P1 Gen 7 boasts a massive battery that's also replaceable, should you ever need to upgrade. Plus, it supports rapid-charging technology, so when you need a charge, simply plug in for 60 minutes and get 80% capacity.
  • When Every Pixel Counts
    When premium displays really matter, the P1 Gen 7 laptop has you covered. All of your choices include wide-angle views, low blue light to prevent eye strain, and X-Rite factory colour calibration to ensure colour accuracy when you're creating. You can also choose a touchscreen model with millions of pixels for premium visuals.
  • Optimal Software Performance
    Software and apps run flawlessly on the P1 Gen 7 workstation, which boasts a long list of independent software vendor (ISV)* certifications. Whether you work in Adobe, AutoCAD, Maya or something else, you can trust that we've eliminated compatibility issues and potential crashes, so you'll enjoy great project-output quality without hiccups.*See the complete list of ISV certifications
  • Smooth& Efficient
    Go ahead- push your device to perform. The ThinkPad P1 Gen 7 mobile workstation offers advanced thermals, including liquid metal cooling on select models, and an innovative Flex Cooling System, a fan-based cooling mechanism. Plus a dual-outlet exhaust system optimizes airflow and keeps your system running efficiently.
  • Huge Memory Reserve& Performance Capacity
    Compile code faster and streamline app development on the ThinkPad P1 Gen 7 workstation. An industry first, this laptop features customer-replaceable LPCAMM2 memory to align with your evolving needs. It boasts lower latency, better bandwidth, and faster speeds to run multiple applications simultaneously, reducing load times for heavy-duty programs.
  • Steadfast Security
    Biometrics provide extra protection on the P1 Gen 7 workstation, from the fingerprint reader to facial recognition software. ThinkShield, our comprehensive suite of security solutions, boasts discrete Trusted Platform Module (dTPM) to encrypt critical data. Plus Intel Threat Detection Technology helps prevent ransomware, cryptojacking, and more.
  • Energy Efficient
    Energy efficiency makes sense. In the short-term, it can lower monthly costs and in the long term, it helps sustain resources in demand. The P1 Gen 7 mobile workstation includes several certifications, including ENERGY STAR 8.0 and TCO 9.
  • Relies on Recycled Components
    This ThinkPad uses recycled magnesium- 90% and 75% in the keyboard frame and top cover respectively. The bottom cover uses 55% recycled aluminum, while the AC adapter uses 30% post-consumer content (PCC) recycled plastic. Plus, packaging is plastic-free!
  • ThinkPad Reliability
    Even with its efficiency and recycled materials, you can count on the P1 Gen 7 for durability. With MIL-STD-810H certification, it meets or exceeds 12 standards, 26 procedures, and 200+ quality checks ensure that these devices run in extreme conditions.
Lenovo ThinkPad P1 Gen 7 - AI Ready - 16" - Intel Core Ultra 7 - 165H - Intel Evo vPro Enterprise Platform - 32 GB RAM - 1 TB SSD - UK
Mobile workstation - AI Ready
Operating System
Win 11 Pro - English
Platform Technology
Intel Core Ultra 7 (Series 1) - 165H / 1.4 GHz, up to 5 GHz / 24 MB Cache
Neural Processor Unit (NPU)
Intel AI Boost
32 GB LPDDR5X (1 x 32 GB)
Storage
1 TB SSD - TCG Opal Encryption 2, NVMe, Performance
Display
16" 2560 x 1600 / WQXGA @ 165 Hz
Graphics
Video Memory
8 GB GDDR6 SDRAM
Input Device
Keyboard, TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax/be, Bluetooth 5.4
Security
Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
35.44 cm x 24.12 cm x 1.705 cm
1.82 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
TCO Certified Notebooks 9, TCO Certified, generation 10, for notebooks, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
272 kg carbon emissions
Base warranty - 3 years - pick-up and return , Base warranty - battery - 1 year , Extended warranty - 3 years - on-site - response time: next business day
Bundled Services
3 Years Lenovo Premier Support, CO2 Offset 0.5 ton (2nd Gen)
Operating System
Windows 11 Pro - English
Processor / Chipset
CPU
Intel Core Ultra 7 (Series 1) 165H / 1.4 GHz
Max Turbo Speed
5 GHz
Number of Cores
16-core
Cache
24 MB
Platform Technology
Integrated memory controller
Intel AI Boost
RAM
32 GB (1 x 32 GB)
Max RAM Supported
64 GB
LPDDR5X SDRAM
Speed
7467 MHz
Rated Speed
3734 MHz
LPCAMM2
Slots Qty
1
Empty Slots
0
Storage
Main Storage
1 TB SSD M.2 2280 PCIe 4.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe), Performance
RAID Level
RAID 0, RAID 1
Display
16" - IPS
Resolution
2560 x 1600 (WQXGA)
V-Sync Rate at Max Res.
165 Hz
Widescreen
Image Aspect Ratio
16:10
Image Brightness
500 cd/m²
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Colour Gamut
100% sRGB
Anti-glare, Low Blue Light technology, DC dimming, X-Rite factory colour calibration, 91.7% screen-to-body ratio
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
8 GB GDDR6 SDRAM
Max Monitors Supported
3 external monitor(s)
Video System Features
Advanced Optimus, Dynamic Boost 2.0, Direct X 12 Ultimate
Camera
Resolution
5 Megapixel
Camera Features
Privacy shutter, IR camera, Windows Hello, fixed focus, Ultrasonic Human Presence Detection
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3306
High Definition Audio, Dolby Atmos
Audio Features
Input: Dolby Voice, far-field
Input
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, glass touchpad, haptic touchpad
Communications
Wireless
Wireless Controller
Intel WI-FI 7 BE200
Dual stream (2x2)
Lithium polymer
90 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
170 Watt
Connections & Expansion
Slots
2 x M.2 (PCI Express 4.0 x4) (1 free)
Interfaces Details
USB 3.2 Gen 1 (Always On) , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , 2 x USB4 (supports Thunderbolt 4, DisplayPort 2.1 Alt Mode) (Power Delivery 3.0) , HDMI (8K support) , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Express Card)
Software
Software Included
Intel Connectivity Performance Suite
Case Material
Aluminium (top), aluminium (bottom)
Security
Administrator password, power-on password, RapidCharge, MIL-STD-810H tested, self-healing BIOS, NVMe password, bottom cover tamper detection
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter
RoHS, FIPS 140-2, TUV Rheinland Low Blue Light Certification, TCG Certified
Localization
Lenovo TopSeller
1.82 kg
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9, TCO Certified, generation 10, for notebooks
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
46
PAIA Version
1.4.0
Packaging Recycled Content
90 % - plastic-free, recycled and/or FSC certified
Bundled Services
5 °C
35 °C
8 - 95%
Essential Accessories (12)
Get more from your purchase from one of our essential accessories
HTR2 Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £192.81
HTR2 Lenovo ThinkPad Basic Topload - Notebook carrying case - 15 In Stock £13.44
HTR2 Lenovo ThinkPad Universal USB-C Dock UK In Stock £141.26
HTR2 Lenovo ThinkPad Thunderbolt 4 Workstation Dock - UK/HK/SGP/MYS In Stock £312.73
HTR2 Lenovo Thinkpad 170W Slim AC Adaptor In Stock £54.14
HTR2 Lenovo ThinkPad Universal Thunderbolt 4 Dock In Stock £250.42
HTR2 Lenovo Casual Toploader T210 - Notebook carrying case 15.6" Black In Stock £15.54
HTR2 Lenovo ThinkPad Universal Thunderbolt 4 Smart Dock In Stock £302.48
HTR2 Lenovo TP ESSENTIAL CASE 16-INCH BACKPACK In Stock £29.45
HTR2 Lenovo LThinkPad Universal USB-C Dock - Docking station - USB-C - H In Stock £150.53
HTR2 Lenovo ThinkPad Essential 16 INCH Topload (Eco) In Stock £25.92
HTR2 Lenovo LENOVO USB-C SLIM TRAVEL DOCK In Stock £50.62
Other bundles (16)
HTR2 Lenovo HDMI to VGA Monitor Adapter In Stock £22.97
HTR2 Lenovo 2m HDMI Cable In Stock £16.94
HTR2 Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £27.09
HTR2 Lenovo Professional Wireless Keyboard In Stock £52.98
HTR2 Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
HTR2 Lenovo Essential Compact Wireless Mouse In Stock £13.76
HTR2 Lenovo USB-C To USB-C Cable - 2m In Stock £31.47
HTR2 Lenovo Hybrid USB-C to USB-C Cable with USB-A Adaptor 1m In Stock £22.89
HTR2 Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.78
HTR2 Lenovo Stereo 3.5mm Headset In Stock £18.69
HTR2 Lenovo USB-C Cable 1M In Stock £15.73
HTR2 Lenovo Thinkvision MC50 Monitor Webcam In Stock £52.48
HTR2 Lenovo ThinkPad Essential Wireless Mouse In Stock £13.44
HTR2 Lenovo Lenovo Professional Wireless Rechargeable Keyboard and Mouse In Stock £58.99
HTR2 Lenovo Lenovo Essential Wired Combo - Keyboard and mouse set - USB In Stock £20.02
HTR2 Lenovo Lenovo - Headset - on-ear - Bluetooth - wireless - USB-A via In Stock £69.39
Screen Size: 16in
Brand: Lenovo
Price Range Ex VAT: £1500+
