Lenovo N308 AIO 19.5" NVIDIA Tegra 4 T40S 2GB 500GB Android 4.2
Quicklinx: 9DNFWS00 Mfr#: 57324303
  • Android 4.2 (Jelly Bean)
  • Tegra 4
  • Bluetooth 4.0
  • IEEE 802.11n
This 19.5 inch All-In-One combines the simplicity of Android with the power and productivity of a home computer. Use apps on the big screen, with much more storage than smaller Android devices, plus an integrated battery for in-home mobility. Enjoy the intuitive operation of Android Jelly Bean 4.2.2 - with thousands of productivity and entertainment apps readily downloadable via Google Play - on a larger scale than typical Android devices. You'll also benefit from multi-user support, allowing you and your friends and family to have separate user profiles.
The gorgeous 250-nit HD+ display yields bright, detailed visuals, and the 2-point infrared multitouch capability is the same responsive, accurate technology we offer in our Windows 8 All-in-One PCs.
With up to 500GB HDD storage, you won't have to worry about where to put all your data, videos, music or photos. Enjoy the convenience of an Android device, with much more storage capacity. This processor is powered by an NVIDIA GeForce GPU with 72 custom cores and ARM's most advanced CPU core yet, plus a second-generation battery-saver core. Delivers record performance and battery life. With the webcam and two 2W stereo speakers, you'll enjoy web chats like you're really there. And like smaller Android devices, the ambient and gravity sensors will detect changes in orientation, lighting, etc. and adjust accordingly. Quickly attach extra storage or transfer multimedia using the easily accessed USB 2.0 ports and 6-in-1 card reader on the side of the PC.
  • Android ease of use
    Enjoy the intuitive operation of Android Jelly Bean 4.2. 2 - with thousands of productivity and entertainment apps readily downloadable via Google Play - on a larger scale than typical Android devices. You'll also benefit from multi-user support, allowing you and your friends and family to have separate user profiles.
  • 19.5" multitouch display
    The gorgeous 250-nit HD+ display yields bright, detailed visuals, and the 2-point infrared multitouch capability is the same responsive, accurate technology Lenovo offer in the all-in-one PCs.
  • NVIDIA Tegra 4 quad-core processing
  • Integrated battery for home portability
    Don't be confined by a power cord; unplug your PC and move it around your home without having to plug back in for up to three hours. Enjoy indoor mobility as you watch a movie in the living room, read a recipe in the kitchen, and play a game in the den.
  • Wireless connectivity to devices and Internet
    Rely on Bluetooth 4.0 to connect third-party Android devices such as game controllers and audio systems, and go online via WiFi 802.11 b/g/n.
  • Integrated 1-megapixel webcam, gravity sensor and ambient sensor
    With the webcam and two 2 W stereo speakers, you'll enjoy web chats like you're really there. And like smaller Android devices, the ambient and gravity sensors will detect changes in orientation, lighting, etc. and adjust accordingly.
  • Convenient connecting ports
  • 50-degree viewing range
    Adjust the kickstand to set your preferred viewing and touch angle from 15 to 65 degrees, or lay the unit flat.
Lenovo N308 - all-in-one - Tegra 4 T40S 1.8 GHz - 2 GB - HDD 500 GB - LED 19.5" - UK
Android PC - all-in-one
1 x NVIDIA Tegra 4 T40S / 1.8 GHz (Quad-Core)
Cache Memory
1 MB
Cache Per Processor
1 MB
RAM
2 GB DDR3 SDRAM
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA 6Gb/s - 5400 rpm
SSD Cache
8 GB
Optical Storage
No optical drive
Card Reader
6 in 1
Monitor
19.5" - LED - 1600 x 900 (HD+) - 16:9
Camera
10Mb LAN, 100Mb LAN, 802.11a, 802.11b/g/n, Bluetooth 4.0
Keyboard
3-cell
OS Provided
48.9 cm x 3.3 cm x 32.3 cm
4.6 kg
Limited warranty - 1 year - pick-up and return
Android PC
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Processor / Chipset
CPU
NVIDIA Tegra 4 T40S
Clock Speed
1.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
1 MB
Cache Per Processor
1 MB
RAM
Installed Size
2 GB
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Hard Drive
HDD
1 x 500 GB
SSD Cache
8 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
6 in 1 card reader
Supported Flash Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
LED - TN
Diagonal Size
19.5"
Native Resolution
1600 x 900 (HD+)
Widescreen Display
Image Aspect Ratio
16:9
Audio Output
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
720p
Input Device
Mouse, keyboard
Keyboard
Wireless
Localization & Layout
Mouse
Wireless
Optical
Audio Input
Microphone
Wireless LAN Supported
Wireless NIC
Broadcom BCM43241
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
1 x LAN , 3 x USB 2.0 (3 in front) , 1 x headphones (1 in front)
Cells
3-cell
Run Time
3.5 hours
Power adapter
Operating System / Software
OS Provided
48.9 cm
3.3 cm
32.3 cm
4.6 kg
10 °C
35 °C
20 - 80%
