Lenovo Miix700 Intel Core M5 6Y54 4GB 128GB SSD 12" Win 10 Pro
Quicklinx: BXN5WS00 Mfr#: 80QL005SUK
  • IEEE 802.11n
Ideapad Miix 700Ideapad Miix 700 Tablet
  • Smart new way to work and play
  • Unique, distinctive watchband hinge
  • Stunning performance and display
  • Next-gen interactive 3D camera option
  • Blazingly-fast Internet speed
  • Super light, weighs less than 1kg
Distinctive Watchband Hinge
Thanks to its unique watchband hinge, the Ideapad Miix 700 will make you stand out from the crowd. As you flip effortlessly between Laptop and Tablet mode in your favorite coffee shop or café, you're sure to attract some envious glances.
Advanced 3D Camera (Optional)
With Intel® RealSense™ technology, you can interact more intuitively with your Ideapad Miix 700 through hand gestures and facial expressions. In addition to taking gaming, entertainment, and video chats to another dimension, the built-in 3D Camera gives you greater control. Please note: the 3D Camera is not available with the LTE (4G) model.
Detachable Folio Keyboard
The Ideapad Miix 700 is not just recognizably different, it also gives you new disruptive ways to work and play.
Adaptive Features
With built-in Trusted Platform Module technology, plus the option of LTE (4G) connectivity, the Ideapad Miix 700 is secure and flexible enough to meet all your needs - at home, in the office, or anywhere else in between. Please note: LTE (4G) is not available with the 3D Camera model.
Ultra-Fast Internet Speeds
With blazing-fast 802.11 a/c WiFi and Bluetooth® 4.0 connectivity, you'll be able to connect to the Internet wherever you go. In fact, 802.11 a/c WiFi delivers up to 3X the connection speeds of 802.11 b/g/n.
Up to Windows 10 Pro
Windows 10 Pro is designed to empower you and your business. It allows you to do great things across your devices securely with anyone, anywhere, and at any time. Fitting a variety of budgets, it's also very easy to use. So you can get more done right from the start.
Full HD+
The 12" FHD+ (2160 x 1440) display delivers bright, crisp visuals in 16:9 widescreen.
Active Pen with WRITEit
The Ideapad Miix 700 takes things up a notch by supporting Active Pen technology. Active Pen lets you draw, write, edit, and compose documents just as if you were using a pen and paper.
Smile, Swap, and Sort - in Seconds.
Lenovo® Photo Master combines a modern photo library, with powerful, easy-to-use navigation, and editing tools. Now, with features such as Auto Face Replace and Smart Event Sort, you can quickly organize and optimize your photos to perfection.
Lenovo DOit Apps
Do more with your Ideapad Miix 700 with premium Lenovo applications like SHAREit, which lets you share files quickly without network charges or even a WiFi connection.
Lenovo IdeaPad Miix 700-12ISK - 12" - Intel Core m5 - 6Y54 - 4 GB RAM - 128 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core m5 (6th Gen) - 6Y54 / 1.1 GHz, up to 2.7 GHz / 4 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
128 GB SSD
Display
12" LED backlight touchscreen 2160 x 1440 / Full HD Plus
Graphics
Intel HD Graphics 515
Input Device
Keyboard, digitizer, touchpad, digital pen
Keyboard
802.11a/b/g/n/ac, Bluetooth 4.1
4-cell - up to 9 hours
Ambient light sensor, G-sensor, hall sensor
29.2 cm x 21 cm x 9 mm
750 g
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
128 GB SSD M.2 SATA 6Gb/s
Display
12" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
2160 x 1440 (Full HD Plus)
Widescreen
Image Aspect Ratio
3:2
Image Brightness
400 cd/m²
Audio & Video
Graphics Processor
Sound
Stereo speakers, two microphones
High Definition Audio, Dolby Advanced Audio
Input
Keyboard Layout
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
4-cell lithium polymer
40 Wh
Run Time
Up to 9 hours
AC Adapter
Input
Output
40 Watt
Connections & Expansion
Interfaces Details
USB 2.0 , USB 3.0 , Micro-HDMI , Headphone/microphone combo jack , Keyboard
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office 2013 (Trial)
Case Material
Magnesium-aluminum alloy
Integrated Options
Power adapter, keyboard
RoHS
Localization
TopSeller
750 g
Dimensions (WxDxH) / Weight Details
29.3 cm x 22.4 cm x 5.5 mm / 330 g - keyboard dock
Sustainability Information
TCO Certified
ENERGY STAR Certified
