Lenovo MIIX 520 I3-7130U 4GB 128SSD Win 10Pro
Quicklinx: DP1FWS00 Mfr#: 20M30008UK
  • Core i3
  • IEEE 802.11n
Extremely portable and flexible, the Lenovo Miix 520 is designed to fit every mood. Feeling creative? Grab the Lenovo Active Pen 2 and write or draw directly on screen - even editing 3D objects scanned from your surroundings. Need to simplify your day? Let Cortana help - she can now respond to your commands from 4 meters away. Fancy some downtime? Detach the keyboard and the Miix 520 becomes a 12" multimedia-rich tablet with stunning display and crisp sound. Add powerful Quad-Core processing and LTE, and Miix is your perfect companion for every situation.
  • Your versatile 2-in-1 companion
    Sleeker than ever, the Miix 520 is whisper-thin and effortlessly portable. Featuring a modern one-piece aluminum alloy body, this elegant 2-in-1 will complement your lifestyle wherever you go. All you need to do is decide which color bests suits you-Platinum or Iron Gray?
  • Do more with Active Pen 2
    With 4,096 levels of sensitivity, the Lenovo Active Pen 2 emulates the feeling of a pen-on-paper experience. Best of all, it will transform your Miix 520 into a digital canvas or smart assistant, instantly.
  • Unleash your creativity at a touch
    Together, Lenovo Active Pen 2 and Windows Ink open up a world of creativity and time-saving shortcuts. With a few strokes of the pen on screen, you can post updates and comments on social media, reply to emails, generate directions by tracing a route in Bing Maps, and so much more. In addition, your handwritten notes can be transformed into reminders and synced across all your Windows devices.
  • Say hello to Windows Cortana
    From giving directions to finding information, from setting reminders to managing to-do lists, Cortana can help you to get things done without you lifting a finger. With specially engineered far-field microphones, this voice-activated digital assistant can hear your commands from across the room-even if your Miix 520 is closed.
  • Power, speed, and peace of mind
    The Miix 520 delivers unprecedented power for a 2-in-1. Featuring the latest Intel quad-core processing and up to 1 TB PCIe SSD storage, you'll enjoy exceptional performance and responsiveness, plus lightning-fast boot-ups and transfer times, anywhere. In addition, with up to 16 GB of memory, you'll be able to run more apps, larger programs, and bigger files-without fear of your Miix 520 lagging.
  • Watchband hinges that tick all the boxes
    Made from 280 individual pieces of stainless steel, the hinges provide strength and flexibility. Adjustable up to 150°, they help you find your perfect viewing angle for watching videos, typing, or using the touchscreen. Password? It's on the tip of your finger With an optional fingerprint reader and Windows Hello, you can log in to your Miix 520 around three times faster than typing a password. It's simple, and above all, safe: each login is wrapped in three layers of protection designed so that neither your fingerprint information nor credentials ever leave your device.
  • Everything's crystal clear
    Featuring a 12.2" touchscreen with Full HD resolution and wide-angle viewing, the Miix 520 delivers stunning detail and clarity. Thanks to an exceptional range of colors, the display on this 2-in-1 will bring all your entertainment and multimedia to life.
  • No WiFi? No problem
    Thanks to the optional LTE connection, you can stay in touch with friends and family without a WiFi connection. As long you're on a cellular network, you can Skype, share thoughts on Twitter, and sync your mailbox too. Plus, with its dual antenna enhancing data connectivity, the Miix 520 will pick up a wider range of signals for a more stable connection.
  • Bring everyday objects to life
    You live in a 3D world, so why settle for 2D? With the optional WorldView camera, you can now scan objects, overlay them on top of a 2D photo, re-arrange their shape-and send them to a 3D printer. And with the host of additional 3D capabilities that Windows 10 brings, it's never been easier to create, capture, and share 3D moments.
Lenovo Miix 520-12IKB - 12.2" - Intel Core i3 - 7130U - 4 GB RAM - 128 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit
Intel Core i3 (7th Gen) - 7130U / 2.7 GHz / 3 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
128 GB SSD - NVMe
Display
12.2" LED backlight touchscreen 1920 x 1200 / WUXGA
Graphics
Intel HD Graphics 620
Input Device
Keyboard, digitizer, touchpad, digital pen
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
2-cell - up to 8 hours
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
Iron grey
Dimensions (WxDxH) - tablet
30 cm x 20.5 cm x 0.99 cm
880 g
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i3 (7th Gen) 7130U / 2.7 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Smart Cache
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
1067 MHz
Storage
Main Storage
128 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
12.2" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Aspect Ratio
16:10
Audio & Video
Graphics Processor
Intel HD Graphics 620 - up to
Camera
Resolution
8 Megapixel (rear), 5 Megapixel (front)
Camera Features
Rear camera with auto focus
Sound
Stereo speakers, four microphones
Dolby Audio
Input
Keyboard Backlight
Keyboard Layout
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
2-cell Lithium Ion
39 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
USB 3.0 , USB-C 3.1 Gen 1 (supports DisplayPort 1.2a Alt Mode) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Iron grey
Security
Power adapter, keyboard, Lenovo Active Pen 2
Localization
880 g
Dimensions (WxDxH) / Weight Details
30.39 cm x 21.91 cm x 0.6 cm / 380 g - keyboard dock , 30 cm x 20.5 cm x 0.99 cm / 880 g - tablet
Sustainability Information
TCO Certified
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
DP1F Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £192.18
Other bundles (1)
DP1F Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
