A 10" tablet and PC in one, the affordable Miix 310 is eminently mobile, so you won’t feel confined to a wireless signal, physical keyboard, or budget. The detachable keyboard makes it easy to convert from PC to tablet mode, and the battery can last for a long time of local video playback on the gorgeous display. Take it anywhere!
Intel Atom processor
Fast browsing, stunning visuals, and responsive performance were already hallmarks of this series of quad-core processors for tablets. The latest updates are smaller and more affordable, but just as powerful. Whether for work or play, this tablet's processor will more than keep up. -
Windows 10 Home
It is the familiar feel of Windows, only improved. The Start menu is back, better than ever. Expand it, customize it, make it yours. Work with more of the devices you care about, such as printers, cameras, and USBs. And enjoy additional security features that help to safeguard you against device theft and malicious software. -
Optional LTE
Why stay confined to a wireless signal? With optional LTE coverage, you can connect to the internet using cellular data, even when no wireless is available. Because a tablet should be truly mobile. -
Detachable keyboard
Laptop or tablet? A detachable keyboard is standard with Miix 310, so the choice is yours. Attach the tablet for increased productivity, adjusting the hinge for picture-perfect viewing just like a traditional laptop PC. Work when you need to, and play when you want to. -
Long battery life
Get up to 10 hours of local video playback on one charge. Your eyes will probably get tired before the battery does! -
Brilliant display with IPS technology
Ideapad Miix 310 comes equipped with a vibrant 10" wide-view (up to 1920x1080) display, complete with in-plane switching (IPS) for vivid colors and nearly 180-degree viewing angles. In addition, the multitouch technology seamlessly integrates with Windows 10, giving you more precise control. -
Thin and light
At a mere 580g and only 9.2mm thick, Miix 310 can be carried just about anywhere. -
Integrated webcams
The 2MP front and 5MP rear cameras will help you enjoy web conferences or online video chats like you're really there.
- Lenovo IdeaPad Miix 310-10ICR - 10.1" - Intel Atom x5 - Z8350 - 4 GB RAM - 64 GB eMMC - UK
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Atom x5 Z8350 / 1.44 GHz, up to 1.92 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Keyboard, touchpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0
- Dockable
- Silver
- Dimensions (WxDxH) - tablet
- 25.74 cm x 17.6 cm x 9.4 mm
- 580 g
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.92 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 64 GB eMMC
Display
- 10.1" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Sound
- Speaker, microphone
Input
- Keyboard Layout
- UK
- Buttonless touchpad
Communications
- Wireless
- Technology
- Lithium Ion
- Capacity
- 33 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 20 Watt, 5 V, 4 A
Connections & Expansion
- Interfaces Details
- Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , 2 x USB 2.0 (on keyboard dock)
- Memory Card Reader
- Yes (microSD)
- Silver
- Dockable
- Included Accessories
- Power adapter
- Localization
- TopSeller
- 580 g
- Dimensions (WxDxH) / Weight Details
- 25.73 cm x 17.56 cm x 9.1 mm / 520 g - keyboard dock
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
