Lenovo M83z Intel Core i5-4460 4GB 500GB AIO Windows 7 Professional
Quicklinx: BDGXWS00 Mfr#: 10C20002UK
  • Microsoft Windows 7 Professional 64-bit Edition
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
The ThinkCentre M83z is built for business collaboration with its full HD 21.5-inch WLED display. With three-stands option and anti-glare solution, it will be perfect for the workplace and the office, as well as in public environments or educational institutions. The Windows 8.1-certified M83z allows business professionals to easily work together on presentations, demos and other collaborative projects. Equipped with up to 4th Generation Intel Core i7 processors and SSHD, the ThinkCentre M83z packs fast, powerful performance into a compact, space-saving design. Users can engage in conference calls with an enhanced 720p HD camera and a digital microphone-based Think VoIP solution and, with physical camera lock and mic mute button, users are able to protect their sensitive conversations with a simple slide/press. Not only powerful and manageable, the M83z is among the industry's most environmentally friendly AIOs – its plastic components are made from more than 40 per cent recycled consumer materials and it meets certifications for energy efficiency and environmental considerations, including EPEAT Gold, Energy Star, EuP 2013 and Cisco EnergyWise.
To Sales/Channel: Mainstream but stylish stand design with latest technologies. It comes with 15 month platform stability and pre-loaded ThinkVantage Technology tools that make PC management simpler while cutting down operating and management costs. The Think VoIP, built with a 720 MP HD camera and a digital microphone with enhanced noise cancellation, as well as some small but careful designs such as the physical camera lock and mic mute button, give you a best-in-class conference experience. Solutions such as Password Manager, TPM support and Chassis Intrusion Switch make it very secure. Space-saving and perfect cable management not only frees up your desk but gives you peace of mind since the green specification of the M83z helps with power savings for your company and also helps the planet. Best-in-class user experience with an affordable price makes a perfect choice for your business.
  • Built for collaboration
    The M83z's 21.5" Full HD LED display offers a wide viewing angle so multiple users can read the screen's contents from different positions around the PC. A seamless Think VoIP experience, 720p HD camera, and digital microphone make this all-in-one perfect for video conferencing.
  • Robust security
    The M83z offers stunning security tools, including USB ports disablement to help prevent data theft and network security risks against unauthorized use of storage devices. Trusted Platform Module encrypts data and key information like passwords and digital certificates, further securing applications, electronic transactions, and online communication. A physical camera lock helps to ensure privacy. Kensington slot doubles as chassis lock.
  • Highly manageable and versatile space-saver
    The M83z offers a clutter-free work environment with an integrated power supply unit that achieves simple, one-cable setup.
  • SuperSpeed USB 3.0
    SuperSpeed USB 3.0 enables very fast file transfer, allowing for lightning-fast copying of large media files, as well as seamless connections between audio and video-related peripherals, backwards-compatible with USB 2.0 devices.
  • View management utility
    Take advantage of multiple active displays, and enjoy faster multitasking: the expanded work area and easier navigation between applications help reduce errors and improve productivity as you extend your desktop across multiple displays.
Lenovo ThinkCentre M83z - all-in-one Core i5 4460S 2.9 GHz - 4 GB - HDD 500 GB - LED 21.5" - UK
Personal computer - all-in-one - administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control, chassis intrusion detection, tilt adjustment
Intel Core i5 (4th Gen) 4460S / 2.9 GHz (, up to 3.4 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
7 in 1
Monitor
21.5" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel HD Graphics 4600
Audio Output
Stereo - integrated
1GbE, 802.11b/g/n, Bluetooth 4.0
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Business black
54 cm x 9.4 cm x 39.6 cm
7.5 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Business black
Processor / Chipset
CPU
Clock Speed
2.9 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Card Reader
7 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Integrated
Built-in microphone
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Preferred Pro USB
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I217-V
Wireless LAN Supported
Wireless NIC
Intel Wireless-N 7260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Wake on LAN (WoL)
Slots
1 (total) / 0 (free) x PCIe Mini Card , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU
2 x USB 3.0 (2 in front) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA output
Administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control, chassis intrusion detection, tilt adjustment
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
RoHS, GREENGUARD, EuP
TopSeller
Power supply
Power Provided
150 Watt
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Sustainability Information
ENERGY STAR Certified
54 cm
9.4 cm
39.6 cm
7.5 kg
BDGX C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
