13th Gen Intel Core processor, beyond performance
Intel's hybrid architecture, paired with industry-leading features, delivers the ultimate gaming experience. Stream, create and compete at the highest levels - 13th Gen Intel Core processors push your gameplay beyond performance, giving you the power to do it all. -
Fully powered NVIDIA GeForce RTX graphics cards, beyond fast
NVIDIA GeForce RTX 40 series Laptop GPUs are beyond fast for gamers and creators. They're powered by the ultra-efficient NVIDIA Ada Lovelace architecture, which delivers a quantum leap in both performance and AI-powered graphics. Experience lifelike virtual worlds with ray tracing, massively boost performance with DLSS 3, and get a competitive edge with Reflex. Discover revolutionary new ways to create and unprecedented workflow acceleration. -
Play hard, run quiet
Move in silence and game loud with Lenovo LOQ's whisper-quiet thermal solution. Its innovative design includes up to 4 heat pipes, dual 85 mm 12V high-speed fans, 28.6% larger air intake, and 24% larger outlet vents. With generous ventilation and up to 135W TDP, your gaming rig will stay cool and quiet even in public areas or library quiet zones. Enjoy uninterrupted gaming sessions without drawing unwanted attention. -
Rugged design, simplicity fueled
The Lenovo LOQ 15IRH8 laptop sports a rugged, practical, sleek design and a signature gaming rear I/O dashboard. It comes with a wide array of ports for easy access and a clean look. With a built-in 1080P FHD camera sporting an e-privacy shutter for greater privacy. Built to strict MIL-STD 810H US military-grade standards for ultimate durability, this laptop is as tough as the characters you play as. -
Greatness on display
Elevate your gaming experience on a 15.6" FHD display. Your games will come to life with a lightning-fast 144 Hz refresh rate, lifelike colors, and a bright 350-nit screen. Plus, DC dimming ensures low power consumption, helping extend battery life for those long gaming sessions on the go. Get lost in the game with the Lenovo LOQ 15IRH8 laptop. -
Dominate with ergonomic precision and accuracy
Unlock your ultimate typing and gaming potential with the Lenovo LOQ keyboard. With classic tactile touch-feel and 1.5mm key travel, you'll enjoy lightning-fast actuation and 100% anti-ghosting for unmatched accuracy. The full-sized arrow keys and number pad help you stay in control in any scenario. -
Charge up your game
Push your battery life to its max and embrace the industry-shaking Super Rapid Charge. Charge up your 60 Whr battery in a heartbeat - from 0 to 30% in 10 minutes, 0 to 70% in 30 minutes, and 0 to 100% in 80 minutes.
- Lenovo LOQ 15IRH8 - 15.6" - Intel Core i5 - 13420H - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook - 180-degree hinge design
- Operating System
- Win 11 Home - English
- Processor
- Intel Core i5 (13th Gen) - 13420H / 2.1 GHz, up to 4.6 GHz / 12 MB Cache
- Memory
- 16 GB DDR5 (2 x 8 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 15.6" 1920 x 1080 / Full HD @ 144 Hz
- Graphics
- NVIDIA GeForce RTX 4050 / Intel UHD Graphics
- Video Memory
- 6 GB GDDR6 SDRAM
- Gaming
- Keyboard
- UK
- Keyboard Backlight
- Yes (RGB)
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.2, Gigabit Ethernet
- Battery
- Up to 4.72 hours
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Storm grey
- 35.96 cm x 26.48 cm x 2.52 cm
- 2.4 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Carbon Footprint
- 412 kg carbon emissions
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 11 Home - English
Processor / Chipset
- CPU
- Intel Core i5 (13th Gen) 13420H / 2.1 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 8-core
- Cache
- 12 MB
- Integrated memory controller
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR5 SDRAM
- Speed
- 4800 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2242 PCIe 4.0 x4 - NVM Express (NVMe)
Display
- 15.6" - IPS
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 144 Hz
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 350 cd/m²
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +85 / -85
- Colour Gamut
- 45% NTSC
- Anti-glare, NVIDIA G-SYNC compatible, advanced optimus
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- NVIDIA GeForce RTX 4050 / Intel UHD Graphics - up to
- Video Memory
- 6 GB GDDR6 SDRAM
- Max Monitors Supported
- 2 external monitor(s)
- Video System Features
- Advanced Optimus, Dynamic Boost 2.0, MUX Switch, Direct X 12 Ultimate, NVIDIA DLSS 3
- Gaming
- Camera
- Yes - 1080p
- Camera Features
- Fixed focus, e-camera shutter
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio
- Audio Features
- Output: Nahimic Gaming Audio
Input
- Keyboard, touchpad
- Yes (RGB)
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch touchpad, buttonless touchpad, precision touchpad, 4-Zone RGB backlight
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Wake-on-LAN (WOL), dual stream (2x2)
- Technology
- Lithium polymer
- Capacity
- 60 Wh
- Run Time
- Up to 4.72 hours
- Battery Run Time
- Local video (1080p) playback time (150 nits): up to 4.72 hours
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 170 Watt
Connections & Expansion
- Slots
- 1 x M.2 (PCI Express 4.0 x4) (1 free)
- Interfaces Details
- USB 3.2 Gen 1 , 2 x USB 3.2 Gen 2 , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (140W Power Delivery) , HDMI (8K support) , LAN , Headphone/microphone combo jack
Software
- Software Included
- Microsoft Office (Trial)
- Storm grey
- Case Material
- Polycarbonate ABS (bottom), polycarbonate ABS (top)
- Surface Finish
- Painting
- Security
- Administrator password, hard drive password, power-on password, RapidCharge, self-healing BIOS, LA1 chip
- Included Accessories
- Power adapter
- RoHS, Energy-Related Products (ErP) Lot 3
- Localization
- Lenovo TopSeller
- 2.4 kg
Sustainability Information
- TCO Certified
- Carbon Footprint
- 5 °C
- 35 °C
- 8 - 95%
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £192.81 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo Depot Repair - Extended service agreement - parts and | In Stock | £52.27 |
Other bundles (8)
Lenovo USB Soundbar for Display | In Stock | £29.89 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £22.97 |
Lenovo 2m HDMI Cable | In Stock | £16.94 |
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £27.09 |
Lenovo Professional Wireless Keyboard | In Stock | £52.98 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.01 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.78 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £52.48 |
