Recognizably different from the competitors, the Yoga 900 is unbelievably thin and elegant. From the 360° watchband hinge to the eye catching color options, this 2-in-1 will turn heads. Packed with the high processing power and customizable features, your Yoga 900 will be your constant companion.
Power User
Life moves fast and so do you. Do more, faster with the powerful processors and customize your experience to make it yours. Drown out distractions with JBL speakers that deliver rich stereo sound and premium Dolby Home Theater for an immersive audio experience. -
On the Go
Yoga 900 is ultraportable - it's perfect for doers on the go. Bend it, flip it, or fold it to experience your apps in a way you never have before. -
Work or Play
The QHD+ display with In-Plane Switching (IPS) technology allows for vivid colors and looks great from any angle. Into marathons? Enjoy movies or TV shows from your favorite streaming service. Working from home? Take productivity to the next level with an improved keyboard and dedicated function row and enjoy web conferences or online video chats like you're really there with the integrated webcam. -
Cool Factor
It's in the details. Lenovo re-engineered the fan to allow the Yoga 900 to stay thin and cool. Specially designed vents in the hinge allow for excellent cooling, dust-resistance, and a clean design that's quiet. And it's beautiful. The elegant hinge is composed of 813 individual components for fluid transitions between modes. Auto Lock hinge technology allows you to easily open and close the laptop, even with one hand.
- Lenovo Yoga 900-13ISK - 13.3" - Intel Core i5 - 6300U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Ultrabook - flip design
- Operating System
- Win 10 Pro
- Processor
- Intel Core i5 (6th Gen) - 6300U / 2.4 GHz, up to 3 GHz / 3 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" LED backlight touchscreen 3200 x 1800 / QHD+
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 4-cell - up to 9 hours
- Ambient light sensor, G-sensor
- Champagne gold
- 32.4 cm x 22.5 cm x 1.49 cm
- 1.29 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Operating System
- Windows 10 Pro
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6300U / 2.4 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 3200 x 1800 (QHD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- One Glass Solution
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Resolution
- 1 Megapixel
- Sound
- Stereo speakers, two microphones
- High Definition Audio, Dolby Audio Premium
- Audio Features
- Output: JBL
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Technology
- 4-cell lithium polymer
- Capacity
- 66 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 20 V, 3.25 A
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , USB 2.0 , Headphone/microphone combo jack , USB-C
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Champagne gold
- Case Material
- Aluminum, magnesium-aluminum alloy
- Integrated Options
- Administrator password, hard drive password, power-on password, digital compass, 1 USB 2.0 (DC-In combo), 1 USB 3.0 with Video-out, Pseudo Gyro
- Included Accessories
- Power adapter
- RoHS
- Localization
- 1.29 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
