3840 x 2160@60Hz
1 x HDMI
2 x USB-A, 2 x USB-C
The Lenovo Slim USB-C Travel Dock provides a productivity boost to the user by delivering port expansion, high-resolution display support and optimum power delivery anywhere, at home, at work and anywhere in between
To check if the Dock is compatible with your system.
                Anywhere hybrid productivityEmbrace remote work with the stylish Lenovo USB-C Slim Travel Dock, designed for the modern professional. This 8-port device isn't your regular dock- it's a productivity powerhouse for every location.
                Unleash visual brillianceFeaturing 4K@ 60 Hz resolution support, this dock ensures high-quality, lag-free visuals, whether you're engaged in a critical video conference or lost in creativity. Plus, the USB ports offer smooth data transfer, enhanced by innovative cable management.
                Plug, play, and power your laptopThis dock is fashioned to support a smooth multi-device connection, making transitions and collaborations a breeze. Designed to be universal, it supports any USB-C laptop* up to 65W via a single cable connection, ensuring you connect, communicate, and create more effectively.
                Balance aesthetics and sustainabilityThe Lenovo USB-C Slim Travel Dock embodies a powerful statement in a sleek, compact form. Its Eclipse Black exterior captures its internal power and efficiency. More than just a pretty face, it includes a 66% Post-Consumer Recycled Content (PCC) exterior, marrying high performance with environmental consciousness.
- Lenovo - docking station - USB-C - HDMI
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI
- 14 cm x 5.5 cm x 1.08 cm
- 108 g
- Eclipse black
- 3-year warranty
- Product Type
- Docking station
- 14 cm
- 5.5 cm
- 1.08 cm
- 108 g
- Enclosure Colour
- Eclipse black
Video
- Max Resolution Details
- 3840 x 2160 - 60 Hz (HDMI)
- 1 x display / video - HDMI - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 2 x USB-C 3.1 Gen 2 - 24 pin USB-C
- Cables Included
- 1 x USB-C cable
- 65W power delivery
- CB, FCC, ICES, RCM, VCCI, BSMI, Ukraine, EAC, KC
- OS Required
- Windows 10, Google Chrome OS, Apple MacOS, Linux
- Limited warranty - 3 years
- Shipping Width
- 18 cm
- Shipping Depth
- 9.2 cm
- Shipping Height
- 2.8 cm
- Shipping Weight
- 191 g
- 0 °C
- 35 °C
