Lenovo Lenovo ThinkPad T14 G4 I5-1335U 16GB 256GB W11P
Quicklinx: HKP6WS00 Mfr#: 21HD003FUK
Screen Size: 14in
Processor Model: I5-1335U
Operating System: Windows 11 Pro
Hard Drive Capacity: 256GB
Graphics: Intel Iris Xe Graphics
  • Core i5
  • IEEE 802.11n
£1,007.85 ex VAT
£1,209.42 inc VAT
14" business laptop powered by up to Intel vPro with 13th Gen Intel Core
Highly configurable with an emphasis on security& speed
Environmentally responsible with the use of recycled materials, plastic-free packaging,& reduced-emissions during manufacturing
Lightning-quick memory, storage,& connectivity, including optional 4G LTE
Supports up to 3 independent monitors.
  • Power, speed,& convenience
    Powered by up to Intel vPro  with 13th Gen Intel  Core processing, the Lenovo ThinkPad T14 Gen 4 laptop boasts high performance and blazing-fast memory, storage, and connectivity-it will zip through even your most demanding tasks. Choose from either the U or P Series processors. IT admins appreciate the convenience of remote deployment and manageability, while everyone can get behind the added security with Intel vPro.
  • Environmentally responsible
    While the lightweight chassis is so convenient to carry around, it's the sustainable materials that make owning this machine a true delight. The ThinkPad T14 Gen 4 laptop is composed of 90% recycled magnesium on the C frame, and for the Storm Grey models, there's 55% recycled aluminum on the D cover. Along with post-consumer content, recycled plastic in the enclosures for the speaker and battery, and the AC adapter, the packaging is plastic-free with 90% recycled and/or sustainable materials. Plus, the manufacturing process uses low-temperature soldering.
  • Easy on the eyes
    If you spend hours on your laptop every day, you'll need one that's easy on the eyes. The ThinkPad T14 Gen 4 boasts a number of display options, ranging from a gorgeous 2.8K OLED with Dolby Vision  panel to lower resolution choices that offer touchscreens, PrivacyGuard, and various color gamuts. Plus, most of the displays feature low blue light certifications to help prevent eye fatigue. And with narrower bezels and a high screen-to-body ratio, everyone's sure to appreciate the added screen real estate on this device.
  • Unleash your productivity
    When you're out on the road, you never know what the connectivity situation will be, or whether you'll find an available electrical outlet. The ThinkPad T14 Gen 4 laptop definitely keeps you covered in both regards! Lightning-quick WiFi keeps you online when wireless coverage is available-but if you're out of range, you can also jump online just like a smartphone when you choose the WWAN* configuration.  What's more, with the option of two battery sizes and rapid-charging technology, there's little need to be tethered to an outlet. No matter where the business takes you, you'll always be business-ready.* Optional WWAN availability varies by region and must be configured at time of purchase; it requires a network service provider.
  • Military-grade durability
    We use the US Department of Defense's MIL-STD 810H standards to create a balance of reliability and durability for our ThinkPad laptops. We test against 12 standards and more than 200 quality checks to ensure they run in extreme conditions. These tests cover harsh variables like Arctic wilderness and desert dust storms, including temperature, pressure, humidity, vibration, and more.
  • Security solutions tailored to you
    Biometrics provide extra protection on the ThinkPad T14 Gen 4 laptop- from the fingerprint reader integrated with the power button to the facial recognition software that works with the IR camera. ThinkShield, our comprehensive suite of security solutions, is integral to our laptops. Features like discrete Trusted Platform Module (dTPM) encrypt your data. Human-presence detection works with the infrared camera to automatically lock your device when you move away. And Intel vPro  helps prevent attacks on the OS, login credentials, and more.
Lenovo ThinkPad T14 Gen 4 - 14" - Intel Core i5 - 1335U - 16 GB RAM - 256 GB SSD - UK
Notebook - 180-degree hinge design
Operating System
Win 11 Pro - English
Intel Core i5 (13th Gen) - 1335U / 1.3 GHz, up to 4.6 GHz / 12 MB Cache
16 GB DDR5 (provided memory is soldered)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
14" 1920 x 1200 / WUXGA
Graphics
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.1, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
Security
Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Thunder black
31.77 cm x 22.69 cm x 1.79 cm
1.36 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
TCO Certified Notebooks 9, ENERGY STAR Qualified EPEAT Gold
Base warranty - 3 years - pick-up and return ¦ Base warranty - battery - 1 year ¦ Extended warranty - 1 year - on-site - response time: next business day
Bundled Services
1 Year Lenovo Premier Support
Operating System
Windows 11 Pro - English
Processor / Chipset
CPU
Intel Core i5 (13th Gen) 1335U / 1.3 GHz
Max Turbo Speed
4.6 GHz
Number of Cores
10-core
Cache
12 MB
Integrated memory controller
RAM
16 GB (provided memory is soldered)
Max RAM Supported
32 GB
DDR5 SDRAM
Speed
5200 MT/s
SO-DIMM 262-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe 4.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
Resolution
1920 x 1200 (WUXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
300 cd/m²
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+85 / -85
Colour Gamut
45% NTSC
Anti-glare
Audio & Video
Graphics Processor
Max Monitors Supported
3 external monitor(s)
Video System Features
Functions as Intel UHD graphics (for single-channel memory)
Camera
Yes - 1080p
Camera Features
Privacy shutter, Windows Hello, fixed focus, hybrid FHD/IR camera
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio
Audio Features
Input: Dolby Voice, 360° far-field
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, Fn keys with Unified Communications controls
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6E AX 211
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Wake-on-LAN (WOL), dual stream (2x2)
Wireless Broadband (WWAN)
Generation
4G upgradable
Lithium polymer
52.5 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 watt
Connections & Expansion
Interfaces Details
USB 3.2 Gen 1 (Always On) , USB 3.2 Gen 1 , 2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , HDMI (4K support) , LAN , Headphone/microphone combo jack
Software
Software Included
Glance by Mirametrix
Thunder black
Case Material
Carbon fibre hybrid (top), polyphenylene sulfide (bottom)
Security
Administrator password, system password, power-on password, RapidCharge, MIL-STD-810H tested, NVMe password, Firmware Resiliency 3.0, certificate based BIOS authentication, FIDO (Fast Identity Online) authentication
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
RoHS, Energy-Related Products (ErP) Lot 6, TCG Certified, Energy-Related Products (ErP) Lot 26
Localization
Lenovo TopSeller
1.36 kg
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Bundled Services
5 °C
35 °C
8 - 95%
Essential Accessories (13)
Get more from your purchase from one of our essential accessories
HKP6 Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £25.88
HKP6 Lenovo 65W Standard AC Adapter USB-C In Stock £27.84
HKP6 Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.42
HKP6 Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £192.18
HKP6 Lenovo 65W USB-C DC Travel Adapter In Stock £41.18
HKP6 Lenovo ThinkPad Basic Topload - Notebook carrying case - 15 In Stock £13.41
HKP6 Lenovo ThinkPad Universal USB-C Dock UK In Stock £141.19
HKP6 Lenovo ThinkPad Thunderbolt 4 Workstation Dock - UK/HK/SGP/MYS In Stock £312.54
HKP6 Lenovo ThinkPad Universal Thunderbolt 4 Dock In Stock £249.59
HKP6 Lenovo Casual Toploader T210 - Notebook carrying case 15.6" Black In Stock £15.54
HKP6 Lenovo TP ESSENTIAL CASE 16-INCH BACKPACK In Stock £29.42
HKP6 Lenovo LThinkPad Universal USB-C Dock - Docking station - USB-C - H In Stock £150.53
HKP6 Lenovo ThinkPad Essential 16 INCH Topload (Eco) In Stock £25.78
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
HKP6 Lenovo Keep Your Drive Add On - extended service agreement - 3 years In Stock £45.96
HKP6 Lenovo 3Y Premier Sup upgrade f/1Y Premier Sup In Stock £137.91
Other bundles (14)
HKP6 Lenovo USB Soundbar for Display In Stock £29.71
HKP6 Lenovo HDMI to VGA Monitor Adapter In Stock £22.98
HKP6 Lenovo 2m HDMI Cable In Stock £16.94
HKP6 Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
HKP6 Lenovo Essential Compact Wireless Mouse In Stock £13.70
HKP6 Lenovo USB-C To USB-C Cable - 2m In Stock £31.43
HKP6 Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.75
HKP6 Lenovo USB-C Cable 1M In Stock £15.73
HKP6 Lenovo Thinkvision MC50 Monitor Webcam In Stock £52.23
HKP6 Lenovo ThinkPad 16GB DDR4 3200 SoDIMM Memory G2 In Stock £135.50
HKP6 Lenovo ThinkPad Essential Wireless Mouse In Stock £13.64
HKP6 Lenovo Lenovo Essential Wired Combo - Keyboard and mouse set - USB In Stock £20.00
HKP6 Lenovo Lenovo - Headset - on-ear - Bluetooth - wireless - USB-A via In Stock £69.33
HKP6 Lenovo Performance FHD Webcam In Stock £51.22
Screen Size: 14in
Brand: Lenovo
Price Range Ex VAT: £1000 - £1500
