Our thinnest& lightest mobile workstation with hi-res 14? display options
AI-assisted productivity& enhanced work efficiency for anywhere business
Independent software vendor (ISV) certifications like Adobe, Altair,& AVID
Meets the multifaceted needs of educators, students,& entry-level professionals.
Portable Powerhouse to Push Your Limits
Boasting robust processing capabilities, the 14? Lenovo ThinkPad P14s Gen 5 mobile workstation is driven by AMD Ryzen PRO processors. Pro-grade AMD Radeon graphics deliver seamless rendering of high-quality image and video files. Plus, tackle heavy-duty computing tasks with dedicated AI engines that allow for extended productivity all day long. -
Accomplish More From Anywhere
The P14s Gen 5 is built for improved efficiency and portability. It ensures reliable connectivity with advanced WiFi and optional WWAN technology to stay online on the go. And, enjoy robust ports and swift memory for seamless multitasking. Ideal for power users and entry-level professionals, it achieves peak performance without breaking the bank. -
Boundless Brilliance in Every Visual
Savor visual excellence on the P14s Gen 5 AMD workstation with up to a 2.8K OLED display and touchscreen options. Slim bezels maximize viewing area for an immersive experience. But the best part? Choose displays with TÜV Eyesafe low blue light-certification to prevent eye strain and 3M optical solutions to optimize brightness and power usage. -
Get Ready for Anything With Extended Comfort
Our lightweight mobile workstation comes with an improved keyboard design for easy access and a customizable Trackpoint Quick Menu. Its dual-fan system and well-placed rear vents facilitate superior cooling. And the Communication Bar atop boasts a 5MP camera and high-fidelity mics for crisp audio-visual quality- perfect for online collaboration. -
Empowering Workflows With Certified Excellence
The powerful P14s Gen 5 AMD mobile workstation features independent software vendor (ISV)-certified apps (ANSYS, AVID, etc.) that guarantee reliable and consistent performance for heavy workloads. It's certified ENERGY STAR 8.0 to reduce costs. Plus, it's partially comprised of recycled plastics and metals and comes in plastic-free packaging.*See the complete list of ISV certifications -
Protected Data, Proven Resilience
The P14s workstation delivers enduring data-device protection with advanced ThinkShield security features. The discrete Trusted Platform Module (dTPM) uses encryption, while the biometric fingerprint reader enables secure login. Moreover, it's rigorously tested to meet MIL-STD-810H standards to withstand extreme conditions and enhance durability.
- Lenovo ThinkPad P14s Gen 5 - AI Workstation - 14" - AMD Ryzen 7 Pro - 8840HS - AMD PRO - 32 GB RAM - 1 TB SSD - UK
- Product Type
- Mobile workstation - AI Workstation - 180-degree hinge design
- Operating System
- Win 11 Pro - English
- Platform Technology
- AMD PRO
- Processor
- AMD Ryzen 7 Pro 8840HS / 3.3 GHz, up to 5.1 GHz / 16 MB Cache
- Neural Processor Unit (NPU)
- AMD Ryzen AI - up to 16 TOPS
- Memory
- 32 GB DDR5 (2 x 16 GB)
- Storage
- 1 TB SSD - TCG Opal Encryption 2, NVMe, Performance
- Display
- 14" 1920 x 1200 / WUXGA @ 60 Hz
- Graphics
- AMD Radeon 780M
- Input Device
- Keyboard, TrackPoint, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3, Gigabit Ethernet
- Security
- Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black
- 31.59 cm x 22.37 cm x 1.77 cm
- 1.31 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- TCO Certified, generation 10, for notebooks, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 194 kg carbon emissions
- Base warranty - 3 years - pick-up and return , Base warranty - battery - 1 year , Extended warranty - 1 year - on-site - response time: next business day
- Bundled Services
- 1 Year Lenovo Premier Support, CO2 Offset 0.5 ton (2nd Gen)
- Product Type
- Mobile workstation - 180-degree hinge design
- AI Level
- AI Workstation
- Operating System
- Windows 11 Pro - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 5.1 GHz
- Number of Cores
- 8-core
- Cache
- L3 - 16 MB
- AMD PRO
- Integrated memory controller
- AMD Ryzen AI
- NPU Performance Up To (TOPS)
- 16 TOPS
- Total Processor Performance Up To (TOPS)
- 39 TOPS
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 96 GB
- Technology
- DDR5 SDRAM - non-ECC
- Speed
- 5600 MT/s
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 1 TB SSD M.2 2280 PCIe 4.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe), Performance
Display
- 14" - IPS
- Resolution
- 1920 x 1200 (WUXGA)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 400 cd/m²
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +85 / -85
- Colour Gamut
- 45% NTSC
- Anti-glare, Eyesafe technology, DC dimming, 3M DBEF5 (Dual Brightness Enhancement Film), 85.73% screen-to-body ratio
Audio & Video
- Graphics Processor
- AMD Radeon 780M
- Max Monitors Supported
- 3 external monitor(s)
- Camera
- Resolution
- 5 Megapixel
- Camera Features
- Privacy shutter, IR camera, Windows Hello, fixed focus
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Audio
- Audio Features
- Input: Dolby Voice, 360° far-field
Input
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Qualcomm NFA725A
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111EPV
- Wake-on-LAN (WOL), dual stream (2x2)
- Technology
- Lithium polymer
- Capacity
- 52.5 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 watt
Connections & Expansion
- Interfaces Details
- USB 3.2 Gen 1 (Always On) , USB 3.2 Gen 1 , 2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery 3.0) , HDMI (4K support) , Headphone/microphone combo jack , LAN
- Black
- Case Material
- Polycarbonate (bottom), carbon fibre (top), glass-fibre (top), polycarbonate (top), carbon fibre (bottom)
- Security
- Administrator password, power-on password, RapidCharge, MIL-STD-810H tested, self-healing BIOS, NVMe password, bottom cover tamper detection
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- RoHS, FIPS 140-2, TCG Certified, TÜV Rheinland Low Blue Light, Eyesafe Certified 2.0
- Localization
- Lenovo TopSeller
- 1.31 kg
Sustainability Information
- TCO Certified
- - TCO Certified, generation 10, for notebooks
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 30
- PAIA Version
- 1.4.0
- Bundled Services
- 5 °C
- 35 °C
- 8 - 95%
Essential Accessories (13)
Get more from your purchase from one of our essential accessories
Lenovo 65W Standard AC Adapter USB-C | In Stock | £27.84 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £30.05 |
Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do | In Stock | £192.18 |
Lenovo 65W USB-C DC Travel Adapter | In Stock | £41.19 |
Lenovo ThinkPad Basic Topload - Notebook carrying case - 15 | In Stock | £13.41 |
Lenovo ThinkPad 15.6" Essential Messenger case | In Stock | £26.44 |
Lenovo ThinkPad Universal USB-C Dock UK | In Stock | £141.08 |
Lenovo ThinkPad Thunderbolt 4 Workstation Dock - UK/HK/SGP/MYS | In Stock | £311.69 |
Lenovo Casual Toploader T210 - Notebook carrying case 15.6" Black | In Stock | £15.54 |
Lenovo TP ESSENTIAL CASE 16-INCH BACKPACK | In Stock | £29.42 |
Lenovo LThinkPad Universal USB-C Dock - Docking station - USB-C - H | In Stock | £150.53 |
Lenovo ThinkPad Essential 16 INCH Topload (Eco) | In Stock | £26.27 |
Lenovo LENOVO USB-C SLIM TRAVEL DOCK | In Stock | £50.58 |
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
Lenovo Warranty – 3 YR Premier Support | In Stock | £137.91 |
Lenovo 3YR Prem Sup upgrade from 1YR Prem Support | In Stock | £137.91 |
Other bundles (13)
Lenovo USB Soundbar for Display | In Stock | £29.71 |
Lenovo HDMI to VGA Monitor Adapter | In Stock | £16.09 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.01 |
Lenovo Essential Compact Wireless Mouse | In Stock | £13.76 |
Lenovo USB-C To USB-C Cable - 2m | In Stock | £31.43 |
Lenovo Hybrid USB-C to USB-C Cable with USB-A Adaptor 1m | In Stock | £23.34 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.75 |
Lenovo USB-C Cable 1M | In Stock | £15.73 |
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £36.56 |
Lenovo ThinkPad Essential Wireless Mouse | In Stock | £13.41 |
Lenovo Lenovo Essential Wired Combo - Keyboard and mouse set - USB | In Stock | £20.00 |
Lenovo Lenovo - Headset - on-ear - Bluetooth - wireless - USB-A via | In Stock | £69.31 |
Lenovo Performance FHD Webcam | In Stock | £51.21 |
