The Lenovo Professional wireless rechargeable combo keyboard and mouse is a revolution in productivity and design. Its full-size keyboard features scissor switches that create an elevated typing experience. Its mouse, marvelously crafted from bio-rubber, keeps you comfortable all day and is equipped with an impressive 4,000 DPI sensor. Plus, both the keyboard and mouse are made from eco-friendly 65% recycled material that protects the environment.
                Rechargeable by necessityNever change another battery thanks to the USB-C rechargeable design of this keyboard and mouse combo that delivers up to 3 months of battery life. Add auto-sleep, on/off buttons, and status lights, and working with your peripherals becomes effortless.
                Productive by designEnhance your workflow with the unmatched capabilities of a 3-zone full-size keyboard and a bio-rubber coated mouse sporting 5 programmable buttons plus dynamic scrolling technology. Add 3 device pairing via a unified pairing receiver or Bluetooth and you've got the tools you need to defeat the day.
                Sustainable by natureLenovo cares about planet Earth. That's why they use 65% post-consumer recycled material for the keyboard and mouse.
- Lenovo Professional - keyboard and mouse set - UK - grey Input Device
- Keyboard and mouse set
- Interface
- Bluetooth, 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Numeric Keypad
- Pointing Device
- Mouse - wireless - optical
- Buttons Qty
- 8
- Performance
- 10 million clicks
- Key Switch Type
- Scissor-Switch
- Grey
- Package Type
- Brown box
- 3-year warranty
- Interface
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 43.74 cm x 12.88 cm x 1.48 cm / 586 g , Mouse: 11.129 cm x 6.223 cm x 3.606 cm / 80 g
- Wireless
- UK
- Keyboard Technology
- Scissors
- Key Switch Type
- Scissor-Switch
- Adjustable Height
- Numeric keypad
Pointing Device
- Mouse - wireless
- Buttons Qty
- 8
- Movement Detection Technology
- Optical
- Movement Resolution
- 4000 dpi
- Batteries:
- Lithium
- Performance
- 10 million clicks
- Grey
- Included Accessories
- USB-A to USB-C cable (1 m), Lenovo USB-A Unified Pairing Receiver
- VCCI, BSMI, CB, IC, MIC, MOC, FCC, NTRA, BQB, cTUVus, UkrSEPRO, WPC, SRRC, AiTi, NCC, iDA, RCM, MSIP, BIS, ICASA, TRA, Subtel, ICT, NTC, SIRIM, FAC, CNC, IFETEL, SDPPI, JRF, TUV Mark, ANRT, CERT, TRC, AFTIC, NTA, SDOCo, ANRCETI, MINCOM, STA, ACI, INACOM, TUV NOM
- Package Details
- Brown box
- Key Life Span
- 10 million clicks
- Technology
- Lithium
- Run Time (Up To)
- 3 month
- Shipping Width
- 53.8 cm
- Shipping Depth
- 12.9 cm
- Shipping Height
- 4.2 cm
- Shipping Weight
- 885 g
- Limited warranty - replacement - 3 years
- 0 °C
- 40 °C
- 20 - 95%
