The Lenovo Professional wireless rechargeable combo keyboard and mouse is a revolution in productivity and design. Its full-size keyboard features scissor switches that create an elevated typing experience. Its mouse, marvelously crafted from bio-rubber, keeps you comfortable all day and is equipped with an impressive 4,000 DPI sensor. Plus, both the keyboard and mouse are made from eco-friendly 65% recycled material that protects the environment.
Rechargeable by necessity
Never change another battery thanks to the USB-C rechargeable design of this keyboard and mouse combo that delivers up to 3 months of battery life. Add auto-sleep, on/off buttons, and status lights, and working with your peripherals becomes effortless. -
Productive by design
Enhance your workflow with the unmatched capabilities of a 3-zone full-size keyboard and a bio-rubber coated mouse sporting 5 programmable buttons plus dynamic scrolling technology. Add 3 device pairing via a unified pairing receiver or Bluetooth and you've got the tools you need to defeat the day. -
Sustainable by nature
Lenovo cares about planet Earth. That's why they use 65% post-consumer recycled material for the keyboard and mouse.
 - Lenovo Professional - keyboard and mouse set - UK - grey Input Device
 - Keyboard and mouse set
- Interface
 - Bluetooth, 2.4 GHz
- Wireless Receiver
 - USB wireless receiver
- Connectivity Technology
 - Wireless
- Localization and Layout
 - UK
- Numeric Keypad
- Pointing Device
 - Mouse - wireless - optical
- Buttons Qty
 - 8
- Performance
 - 10 million clicks
- Key Switch Type
 - Scissor-Switch
 - Grey
- Package Type
 - Brown box
 - 3-year warranty
- Interface
- Wireless Receiver
- Dimensions (WxDxH) / Weight
 - Keyboard: 43.74 cm x 12.88 cm x 1.48 cm / 586 g , Mouse: 11.129 cm x 6.223 cm x 3.606 cm / 80 g
 - Wireless
 - UK
- Keyboard Technology
 - Scissors
- Key Switch Type
 - Scissor-Switch
- Adjustable Height
 - Numeric keypad
Pointing Device
 - Mouse - wireless
- Buttons Qty
 - 8
- Movement Detection Technology
 - Optical
- Movement Resolution
 - 4000 dpi
- Batteries:
 - Lithium
- Performance
 - 10 million clicks
 - Grey
- Included Accessories
 - USB-A to USB-C cable (1 m), Lenovo USB-A Unified Pairing Receiver
 - VCCI, BSMI, CB, IC, MIC, MOC, FCC, NTRA, BQB, cTUVus, UkrSEPRO, WPC, SRRC, AiTi, NCC, iDA, RCM, MSIP, BIS, ICASA, TRA, Subtel, ICT, NTC, SIRIM, FAC, CNC, IFETEL, SDPPI, JRF, TUV Mark, ANRT, CERT, TRC, AFTIC, NTA, SDOCo, ANRCETI, MINCOM, STA, ACI, INACOM, TUV NOM
- Package Details
 - Brown box
- Key Life Span
 - 10 million clicks
- Technology
 - Lithium
- Run Time (Up To)
 - 3 month
- Shipping Width
 - 53.8 cm
- Shipping Depth
 - 12.9 cm
- Shipping Height
 - 4.2 cm
- Shipping Weight
 - 885 g
 - Limited warranty - replacement - 3 years
 - 0 °C
 - 40 °C
 - 20 - 95%
