The Lenovo Essential Wired Combo keeps things uncomplicated. This durable keyboard and mouse plugs into any USB port with wired reliability you can count on. The tough waterproof membrane can handle accidental spills without risking performance. Enjoy feel-good typing with quiet keys and number pad in a modern space saving layout. An ergonomic full size mouse offers comfort and support for all day use. Increase your productivity as you smoothly complete tasks with the 1000dpi high resolution optical sensor.
Reliable connectivity
The keyboard and mouse set connects via a USB interface, ensuring a stable and uninterrupted connection while in use. -
Ergonomic design
Features adjustable height settings, allowing users to customize their typing and clicking position for better comfort. -
Precise tracking
The optical mouse utilizes advanced movement detection technology for smooth and accurate cursor control on various surfaces. -
Safety compliance
The combo meets several compliance standards including UL, TUV, and FCC, providing assurance of quality and safety.
 - Lenovo Essential Wired Combo - keyboard and mouse set - QWERTY - UK - black Input Device
 - Keyboard and mouse set
- Interface
 - USB
- Connectivity Technology
 - Wired
- Localization and Layout
 - QWERTY UK
- Hot Keys Function
 - Copilot key
- Protection
 - Spill-resistant
- Numeric Keypad
- Pointing Device
 - Mouse - wired - optical
- Buttons Qty
 - 3
- Performance
 - 1 million clicks
 - Black
 - 1-year warranty
- Interface
 - USB
- Dimensions (WxDxH) / Weight
 - Keyboard: 42.4 cm x 14.6 cm x 2 cm / 570 g , Mouse: 11.1 cm x 6.2 cm x 3.4 cm / 69 g
- Hot Keys Function
 - Copilot key
 - QWERTY UK
- Adjustable Height
- Protection
 - Spill-resistant
 - Numeric keypad
Pointing Device
 - Mouse - wired
- Buttons Qty
 - 3
- Movement Detection Technology
 - Optical
- Movement Resolution
 - 1600 dpi
- Performance
 - 1 million clicks
 - Black
- Cable Length
 - 1.8 m
 - AAA, BSMI, CB, C-Tick, EAC, FCC, IC, KCC, TUV, UL, VCCI
- Key Life Span
 - 10 million clicks
- OS Required
 - Windows 10, Windows 11
- Shipping Width
 - 50.8 cm
- Shipping Depth
 - 17.9 cm
- Shipping Height
 - 4.5 cm
- Shipping Weight
 - 910 g
 - Limited warranty - replacement - 1 year
 - 0 °C
 - 40 °C
 - 15 - 60% RH
