The Lenovo Wireless VoIP Headset (Teams) is perfectly engineered for the modern hybrid open workspace. Its Microsoft Open Office Teams certification ensures professional call quality and seamless collaboration with Teams.
Use this headset to experience the magic of multi-point Bluetooth capabilities and enjoy an impressive 31 hours of talk time between charges. With its ergonomic design and replaceable memory foam ear cups, it is very comfortable for long-time use.
                Guaranteed performancePut an end to communication hassles with the Lenovo Wireless VoIP Headset. Certified for Microsoft Teams Open Office and optimized for UC platforms, this headset delivers exceptional voice quality, making sure you're always heard loud and clear on calls.
                Multipoint masterpieceImmerse yourself in seamless connectivity with the USB-A Bluetooth Audio Receiver and cutting-edge Multipoint Bluetooth technology. Say goodbye to dropped calls and embrace uninterrupted, crystal-clear communication.
                Unmatched comfortIndulge in unparalleled comfort with the Lenovo Wireless VoIP Headset. Its 140g weight, adaptive headband and plush memory foam earcups, covered in premium leatherette, create a custom-fit luxury experience for your workday.
- Lenovo - headset - USB-A via Bluetooth adapter
- Product Type
- Headset - Bluetooth - wireless - USB-A via Bluetooth adapter
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 109 dB +/- 2.5dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphones Included
- 3
- Controls
- Mute, volume, answer/ignore/end/hold, play/pause/track forward/back
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Product Type
- 140 g
- Black
- Max Operating Distance
- 30 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 109 dB +/- 2.5dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
Microphone
- Boom
- Form Factor
- Headset microphone
- 3
Remote Control
- Controls
- Connector Type
- Wireless adapter (USB)
Cable
- Cable Length
- 1.3 m
- Included Accessories
- Travel pouch, USB-C cable, Bluetooth adapter
- Cable Details
- USB-C charge cable - detachable - 1.3 m
- Supported Host Device OS
- Windows 10 or later, macOS
- CB, BQB, TUV Mark, UKCA, RCM, EAC, cTUVus, FCC, ICES, WPC, BIS, SRRC, SIRIM, KC, IMDA, sDoC, SDPPI, JRF, RAMATEL, ANATEL, BSMI, NCC, ICASA, Plug and Play
- Battery
- Headset battery rechargeable
- Capacity
- 640 mAh
- Run Time (Up To)
- 60 hour(s)
- Recharge Time
- 2 hour(s)
- Limited warranty - replacement - 2 years
- Shipping Width
- 21.1 cm
- Shipping Depth
- 20.6 cm
- Shipping Height
- 7.6 cm
- Shipping Weight
- 430 g
- 0 °C
- 40 °C
- 90%
