This sleek, portable 15.6" laptop pushes gaming performance to a new level. Thermally optimized to run cooler and quieter with a full-sized backlit keyboard, the Lenovo Legion Y540 laptop is primed for those who demand gaming wherever life takes them.
Even more muscle per millimeter
Expert craftsmanship extends beyond design. The Y540 represents the culmination of thousands of engineering hours to deliver a laptop that is both powerful and thin. To support up to 3200 MHz DDR4 memory, PCIe SSD storage, and more, our engineers combined their expertise in battery, I/O placement, thermals, and motherboard design to pack the best hardware into one powerful gaming laptop. -
Take your games to the edge
With its thin bezels, the Y540 packs more than 2 million pixels into a near-edgeless 15-inch FHD display. Combined with up to 144 Hz refresh rate, 300 nits of brightness, and an IPS Antiglare screen, this laptop brings your favorite games to life, for breathtakingly immersive gameplay on the go. -
Go inside the action
Dolby Atmos pulls you into the game with powerful, moving audio that sweeps all around and above you with amazing precision and realism. A leap forward from surround sound, it gives you a competitive edge via the new Sound Radar overlay. Know where specific sounds are coming from and hear audio that heightens your sense of awareness and immerses you in a more intense gaming experience. -
Time to strike
Intense firefights require the most responsive of controls, and the Y540 keyboard delivers best-in-class gaming controls to give you the edge over any opponent. Full-sized and top of the line, this keyboard delivers 100% anti-ghosting, laser-engraved WASD highlights, less than 1 ms response time, white backlighting, and more for ultimate control of your system. Further, the Y540 features Windows Precision drivers with gesture control, for effortless input whether at work or play. -
The Coldfront is here
Heat-the nemesis of gaming performance-is no longer a concern, thanks to Legion Coldfront. Coldfront brings the latest features that a dual-channel thermal system can provide, including individual CPU and GPU cooling for cooler system temperatures, four thermal vents for improved airflow, dedicated heat syncs for cooler keyboard temperatures, and 70 individual fan blades per channel to reduce system noise. -
Fine-tune your gaming style with Lenovo Vantage
Take your gaming to the next level with Vantage, featuring Legion Edge. Spend less time tweaking your settings and more time playing with automated performance, cooling, and power control settings. Get overclock support* for CPU and RAM, full RGB lighting controls*, real-time device performance monitoring, and more-all in one app.*Overclocking and RGB features not available on all models. -
Expand your views
You need to see more from your battle station. The Legion Triple Display Support System utilizes the HDMI 2.0, MiniDisplay, and Type-C ports, allowing the Y540 to connect up to three displays simultaneously for maximum immersion and control. Further, our rear I/O dashboard helps with cable management, keeping your battle station clean and organized for maximum focus on the game. -
Rear port connectivity
The Y540 features a convenient array of ports and connectors; plug in an external device or accessory or simply charge or secure your laptop with the following rear ports, seen above:• 1. USB-C. 2. Mini DisplayPort. 3. USB 3.1 Gen 1[1]. 4. HDMI. 5. Ethernet. 6. AC adapter. 7. Kensington lock slot -
Side port connectivity
The Y540 also features the following side ports and connectors, seen above:• 8. USB 3.1 Gen 1[1]. 9. USB 3.1 Gen 1[1]. 10. Headphone/mic combo
- Lenovo Legion Y540-15IRH - 15.6" - Intel Core i5 - 9300H - 8 GB RAM - 256 GB SSD + 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Core i5 (9th Gen) - 9300H / 2.4 GHz, up to 4.1 GHz / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe + 1 TB HDD / 5400 rpm
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD @ 144 Hz
- Graphics
- NVIDIA GeForce GTX 1660 Ti / Intel UHD Graphics 630
- Video Memory
- 6 GB GDDR6 SDRAM
- VR Ready
- Gaming
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- Up to 10 hours
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Raven black
- 36 cm x 26.7 cm x 2.59 cm
- 2.3 kg
- Localisation
- Specific Absorption Rate (SAR)
- 1.104 W/kg (body) , 1.104 W/kg (limb)
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (9th Gen) 9300H / 2.4 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM370
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Rated Speed
- 1333 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe)
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 5400 rpm
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 144 Hz
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 72%
- Anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- NVIDIA GeForce GTX 1660 Ti / Intel UHD Graphics 630 - up to
- Video Memory
- 6 GB GDDR6 SDRAM
- VR Ready
- Gaming
- Camera
- Yes - 720p
- Resolution
- 1 Megapixel
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3287
- High Definition Audio, Dolby Atmos
- Audio Features
- Output: Harman audio technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch touchpad, white LED backlight
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Dual stream (2x2)
- Technology
- Lithium Ion
- Capacity
- 57 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 (Always On) , 2 x USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (supports DisplayPort 1.2 Alt Mode) , HDMI , LAN , Mini DisplayPort 1.4 , Headphone/microphone combo jack
Software
- Software Included
- Microsoft Office (Trial)
- Raven black
- Case Material
- Polycarbonate ABS
- Security
- Administrator password, hard drive password, power-on password, LED lighting
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS, Energy-Related Products (ErP) Lot 3
- Localization
- 2.3 kg
Sustainability Information
- TCO Certified
