Lenovo Legion Y32p-30 31.5" 4K-UHD-Pro-Gaming-Monitor
Quicklinx: HVB3WS00 Mfr#: 66F9UAC6UK
Diagonal Size: 31.5in
Max Resolution: 3840 x 2160
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
£885.57 ex VAT
£1,062.68 inc VAT
Shatter the barriers that keep you from winning with the Legion Y32p-30 gaming monitor. Immerse yourself in razor-sharp pixels, smooth movements, and minimal ghosting and motion blur. Everything from its 31.5", 3-side NearEdgeless Panel and UHD resolution to its blazing-fast 144Hz refresh rate and 0.2ms Motion Picture Response Time (MPRT) are carefully crafted for a smooth, immersive gaming experience. Its NearEdgeless design ensures undisturbed gameplay, while In Plane Switching helps deliver movie-quality visuals. An impressive 10bit color reproduction supporting 1.07 billion colors, Delta E<2 color accuracy, and DisplayHDR 400 render incredibly vivid, life-like environments. The USB-C docking solution adds a new dimension to your setup, allowing users to simultaneously share files, transfer data and show the content on display, also charge connected devices like laptops, mobile devices, and peripherals, improving the versatility of your gaming ecosystem. Multitasking is a breeze with Picture-in-Picture and Picture-by-Picture (PIP and PBP) with a second window opened as an inset or in split-screen mode. The Keyboard-Video-Mouse switch (KVM Switch) lets you control multiple monitors and systems with ease. Perfect for gaming, and the home office. Legion Y32p-30 is made to help you dominate every game you play, and work at your best in brilliant clarity.
Lenovo Legion Y32P-30 - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class G
Adaptive-Sync Technology
VESA Adaptive-Sync, AMD FreeSync Premium
KVM Switch
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
DWUXGA 3840 x 2160 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
3 ms (Level 3), 0.2 ms (MPRT), 2 ms (Level 4), 4 ms (Level 2), 5 ms (Level 1), 7 ms (off)
Colour Support
1.07 billion colours
Colour Gamut
112% sRGB, 99% sRGB, 90% DCI-P3
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
Dimensions (WxDxH) - with stand (highest position)
71.51 cm x 29.84 cm x 59.98 cm
9.6 kg
English / United Kingdom
RoHS, TUV Rheinland Eye Comfort Certification, TUV Rheinland Eyesafe Display, TUV Rheinland Low Blue Light (Hardware Solution)
3-year warranty
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
31.5"
Viewable Size
32"
Built-in Devices
KVM Switch
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
139
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Picture in picture, picture by picture, Delta E<2 calibration, 3-side NearEdgeless, 10-bit(8-bit + FRC) Colour Depth, 16-zone local dimming, Smart Power technology, Natural Low Blue Light technology, brightness calibration, gaming console support, Auto Ambient Brightness Sensor, HDR400
Raven black
71.51 cm x 29.84 cm x 59.98 cm - with stand (highest position)
9.6 kg
Audio
Speakers
2 x HDMI , DisplayPort 1.4 , USB 3.2 Gen 1 upstream (Type B) , 2 x USB 3.2 Gen 1 downstream , USB-C 3.2 Gen 1 downstream , Audio line-out , USB-C 3.2 Gen 1 upstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
30
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x power cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-C to USB-C cable - 1 m , 1 x USB-A to USB-B cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
55 kWh/1000h
Power Consumption HDR (On mode)
59 kWh/1000h
Power Consumption (Typical)
62 Watt
Power Consumption (Max)
175 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Lenovo Artery, Lenovo Display Control Center
Windows 10, Windows 11
Dimensions & Weight Details
With stand (lowest position) - width: 71.51 cm - depth: 29.84 cm - height: 46.38 cm - weight: 9.6 kg , With stand (highest position) - width: 71.51 cm - depth: 29.84 cm - height: 59.88 cm - weight: 9.6 kg
Shipping Width
90.6 cm
Shipping Depth
17.3 cm
Shipping Height
52.6 cm
Shipping Weight
14.2 kg
Limited warranty - 3 years
Response Time: 1ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Lenovo
Price Range Ex VAT: £750 - £1000
