Lenovo Legion Y27q-20 27" QHD 165Hz 1ms Gaming Monitor
Quicklinx: GWXRWS00 Mfr#: 65EEGAC1UK
The Lenovo Legion Y27q-20 gaming monitor delivers an immersive gaming experience that's sure to get your pulse racing. The IPS wide viewing angle panel ensures stunning clarity with true colors. A 1ms response time and 165 Hz refresh rate give you the edge when it matters most. The innovative AMD Radeon FreeSync technology takes gameplay to a whole new level, churning out ultra-smooth visuals, reducing screen tearing and motion blur.
Lenovo Legion Y27q-20 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Power Consumption (On mode)
32 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
1 ms (extreme), 2 ms (typical), 5 ms (Off)
Colour Support
1.07 billion colours
Colour Gamut
98% DCI-P3 (CIE 1931)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Raven black
61.4 cm x 28.44 cm x 46.89 cm
6.77 kg
English / United Kingdom
CCC, RoHS, Directive 2002/95/EC, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Raven black
61.4 cm x 28.44 cm x 46.89 cm - with stand
6.77 kg
HDMI , DisplayPort , USB 3.1 Gen 1 upstream (Type B) , 3 x USB 3.1 Gen 1 downstream , Headphone/microphone combo jack
Mechanical
Tilt Angle
-5/+22
Swivel Angle
30
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, headphone hook
1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB 3.1 Type A to Type B cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
32 W
32 kWh/1000h
Power Consumption HDR (On mode)
58 kWh/1000h
Power Consumption (Typical)
50 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
Lenovo Artery 2.0
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 28.44 cm - height: 46.89 cm - weight: 6.77 kg , Without stand - width: 61.4 cm - depth: 6.34 cm - height: 36.87 cm - weight: 4.37 kg
Shipping Width
48 cm
Shipping Depth
71.5 cm
Shipping Height
22.5 cm
Shipping Weight
9.7 kg
Limited warranty - 3 years
