The portable, ambidextrous Lenovo Wireless Laser Mouse is perfect for anyone looking for a compact mouse to use every day and while on-the-go. Scroll through documents, spreadsheets, and more with increased accuracy and control with its high-definition laser sensor. An advanced power management system, a high-efficiency laser sensor, and an off switch help to maximize your battery life.
- Lenovo - mouse - 2.4 GHz - Campus
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- 5.6 cm x 9.6 cm x 3.2 cm
- 108 g
- Localisation
- Worldwide (excluding Argentina, Brazil, Korea, Paraguay)
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Movement Resolution
- 1600 dpi
- Scrolling wheel (4-way), battery indicator
- Battery
- 2 x AA type
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Manufacturer Selling Program
- Lenovo Campus
- 1-year warranty
- Mouse
- Wireless Receiver
- 5.6 cm
- 9.6 cm
- 3.2 cm
- 108 g
- Localisation
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- 1600 dpi
- 1 x USB - 4 pin USB Type A
- C-Tick, IC, DOC, MOC, FCC, R&TTE, NTRA, KCC, ANATEL, TELEC
- Lenovo Campus
- AA type
- Installed Qty
- 2
- OS Required
- Limited warranty - replacement - 1 year
- 0 °C
- 40 °C
- 20 - 95%
