Performance and portability come together in the ThinkPad L560. A great choice for on-the-go professionals. The thin and light L560's features include long battery life, robust connectivity, optimized performance, and business-class manageability and security features.
Thin and light design
With its thin and light design, the L560 is a great choice for on-the-go professionals. -
Robust connectivity
Despite being thin and light, the L560 has the ports to connect to the devices you need to get the job done. -
Long battery life
With a long battery life, the L560 will keep your business online even when plug-in power is not on tap. -
Ultra durable
The L560 offers ruggedness and durability against conditions such as high pressure, humidity, vibration, high temperature, temperature shock, low pressure, low temperature, and dust. -
Responsive performance
With plenty of memory, you can run multiple high-end software applications without stalling your PC.
- Lenovo ThinkPad L560 - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 6-cell - up to 11.2 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 37.7 cm x 25.5 cm x 3.085 cm
- 2.38 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
- Optical Drive
- DVD-Writer - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3245
- High Definition Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- 6-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 11.2 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Slots
- 1 x ExpressCard/34 (1 free)
- Interfaces Details
- 4 x USB 3.0 , VGA , Mini DisplayPort , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial)
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Administrator password, hard drive password, power-on password, ThinkVantage Active Protection System, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS, GREENGUARD
- Localization
- TopSeller
- 2.38 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black | In Stock | £17.28 |
