With memory, you can run multiple high-end software applications without stalling your PC. Visuals look great on the ThinkPad L460, thanks to integrated Intel HD graphics. Whether you're creating presentations, writing reports, or kicking back with a movie, the L460 fits the bill.
At just 0.96" thin and weighing in at as little as 1.9 kg, the L460 is a great choice for on-the-go professionals. But, the L460 is also durable. It meets 12 US military-spec tests for ruggedness, durability, and quality. In addition, innovative roll-cage technology and glass-fiber reinforced plastic add extra strength and rigidity.
Enhanced graphics performance
Visuals look great on the ThinkPad L460, thanks to the powerful discrete graphics chip. Whether you’re assembling video presentations, editing product photos, or kicking back with a movie, the L460 fits the bill. -
Thin and light design
Being extremely thick and lightweight, the L460 is a great choice for on-the-go professionals. -
Long battery life
Thanks to its stunning battery life, the L460 will keep your business online even when plug-in power is not on tap. -
Ultra durable
The L460 ensures ruggedness, durability, and quality under the conditions of high pressure, humidity, vibration, high temperature, temperature shock, low pressure, low temperature, and dust. -
Robust connectivity
Despite being thin and light, the L460 has the ports you need to connect to the devices you need to get the job done. -
Responsive performance
With capacitive memory, you can run multiple software applications without stalling your PC.
- Lenovo ThinkPad L460 - 14" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Input Device
- TrackPoint, UltraNav
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 6-cell - up to 12.7 hours
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
- Black
- 33.9 cm x 23.5 cm x 2.43 cm
- 2.02 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3245
- High Definition Audio
Input
- Keyboard, TrackPoint, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
Wireless Broadband (WWAN)
- Generation
- WWAN upgradable
- Technology
- 6-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 12.7 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , Mini DisplayPort , VGA , LAN , Headphone/microphone combo jack , Dock
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- ThinkVantage Rescue and Recovery, Adobe Reader, ThinkVantage System Update, ThinkVantage Product Recovery, Lenovo Solution Center, McAfee LiveSafe (30 days trial)
- Black
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password, 1 USB 3.0 (Always On), ThinkEngine, MIL-STD-810G tested
- Included Accessories
- Power adapter
- RoHS, GREENGUARD
- Localization
- TopSeller
- 2.02 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black | In Stock | £16.62 |
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black | In Stock | £17.63 |
