Lenovo L27Q-10 27" Quad HD Monitor
Quicklinx: FHP9WS00 Mfr#: 65CEGAC1UK
Like an artist's canvas, the Lenovo L27q-10 represents pure perfection of color and detail. From the stunning, borderless design to the superb resolution, this is a monitor that's sure to make an impression.
  • Viewing perfection
    The superb clarity of the high resolution combines with millions of colors for truly exquisite quality.
  • Borderless design
    A super-narrow bezel houses the screen for an optimal display area. With easy cable management, the L27q-10 enhances any environment.
Lenovo L27q-10 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/443122
Energy Class
Class G
Power Consumption (On mode)
30 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.23 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (extreme)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
Warm silver
61.16 cm x 23.7 cm x 46.63 cm
4.95 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
CSA, UL, TUV, BSMI, NOM, SABS, SASO, SEMKO, TUV S, CB, CCC, PSB, DDC/CI, RoHS, PSE Mark, REACH, KC, Kvalitet, KUCAS, KEBS, EAC, DisplayPort 1.2, VESA TMDS, TUV Rheinland Eye Comfort Certification, IEC 950, STZ
3-year warranty
Display Type
Energy Class
Class G
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.23 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (extreme)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Warm silver
4.95 kg
HDMI , DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
Input Voltage
30 W
30 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
45 °C
10 - 80% (non-condensing)
