Getting the right tool to perform a task doesn't mean compromising on design aesthetics. Or having to prioritize work over play. Lenovo L27e-30 packages powerful performance in a elegant form factor that focuses the principles of minimalist design into a stylish centerpiece for the home. While its 27-inch In-Plane Switching panel display creates distortion-free pictures for anyone streaming a coursework video, no matter what angle they sit from the screen, the monitor's clean, simple lines, 3-side NearEdgeless frame and sculpted wedge stand create a picture of elegance and sophistication to suit any modern home. At just 7.1 mm, the ultra-slim screen head is thinner than many phones and makes home workspaces feel truly spacious. Add in the wedge stand's integrated phone holder and concealed cable management and L27e-30's user experience is profoundly clean and clutter-free. When reviewing documents late into the night, it's the little touches that make a big difference. For instance, the monitor's TÜV Rheinland Eye Comfortcertified technology filters harmful wavelengths to protect users' eyes from fatigue. And, once work is done, L27e-30 doubles as a great window into a world of entertainment. Take gameplay, where ghosting, streaking and torn images are a problem banished to history thanks to AMD FreeSync and a rapid 75 Hz refresh rate.
Functional & flattering
With its brand new minimal restyling and 7.1 mm ultra-slim head, Lenovo L27e-30 looks as good in any home as the images it displays on its 27-inch In-Plane Switching panel screen. A screen that floats above its newly upgraded sculpted wedge stand that's engineered for elegance, stability and convenience because it tidies cables invisibly away behind its slender neck and integrates a rack to neatly hold a mobile phone. -
Comfortable from any angle
With its generous 27-inch In-Plane Switching panel display, L27e-30 delivers faultless images even when it's viewed from extreme angles as much as 178°. So, watching videos side-byside with someone at home, everyone sees the same picture with accurate, undistorted colors. And if users need to work at home, say, inputting data well into the night, this monitor safeguards their eyes from fatigue thanks to TÜV Rheinland Eye Comfort-certified technology that filters harmful blue wavelengths. -
Convenience & control for work & entertainment
Press play. And let the video coursework or entertainment flow uninterrupted.
 - Lenovo L27e-30 - LED monitor - Full HD (1080p) - 27"
 - LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/391340
- Energy Class
 - Class E
- Power Consumption (On mode)
 - 17.5 W
- Adaptive-Sync Technology
 - AMD FreeSync
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
 - 0.3114 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 3000000:1 (dynamic)
- Response Time
 - 4 ms (extreme), 6 ms (normal)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 72% NTSC (CIE 1931)
- Input Connectors
 - HDMI, VGA
 - Tilt
- Screen Coating
 - Anti-glare
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Raven black
 - 61.25 cm x 17.49 cm x 47.58 cm
 - 4.53 kg
- Localisation
 - EMEA
 - CCC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, EU RoHS 2002/95/EC
 - 3-year warranty
- Display Type
- Energy Class
 - Class E
- Diagonal Size
 - 27"
 - AMD FreeSync
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.3114 mm
- Pixel Per Inch
 - 82
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
 - Anti-glare
- Backlight Technology
 - WLED
 - Integrated cable management, 3-sided bezeless, 3-side NearEdgeless
 - Raven black
 - 61.25 cm x 17.49 cm x 47.58 cm - with stand
 - 4.53 kg
 - HDMI , VGA , Audio line-out
Mechanical
 - Tilt
- Tilt Angle
 - -5/+22
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x HDMI cable - 1.8 m
- Localisation
 - EMEA
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 17.5 W
- Power Consumption SDR (On mode)
 - 17.5 kWh/1000h
- Power Consumption (Typical)
 - 18 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Power Consumption Sleep
 - 0.5 Watt
 - 0.3 Watt
- Included Software
 - Lenovo Artery, Lenovo Display Control Center
- Dimensions & Weight Details
 - With stand - width: 61.25 cm - depth: 17.49 cm - height: 47.58 cm - weight: 4.53 kg , Without stand - width: 61.25 cm - depth: 4.32 cm - height: 36.77 cm - weight: 3.6 kg
- Shipping Width
 - 71 cm
- Shipping Depth
 - 12.6 cm
- Shipping Height
 - 45.5 cm
- Shipping Weight
 - 6.35 kg
 - Limited warranty - 3 years
