Lenovo L27e-30 27" 1920x1080 4ms VGA HDMI IPS LED Monitor
Quicklinx: HCQBWS00 Mfr#: 66BEKAC2UK
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: HDMI, VGA (HD-15), DisplayPort
2 on order, no confirmed delivery date
£138.01 ex VAT
£165.61 inc VAT
Getting the right tool to perform a task doesn't mean compromising on design aesthetics. Or having to prioritize work over play. Lenovo L27e-30 packages powerful performance in a elegant form factor that focuses the principles of minimalist design into a stylish centerpiece for the home. While its 27-inch In-Plane Switching panel display creates distortion-free pictures for anyone streaming a coursework video, no matter what angle they sit from the screen, the monitor's clean, simple lines, 3-side NearEdgeless frame and sculpted wedge stand create a picture of elegance and sophistication to suit any modern home. At just 7.1 mm, the ultra-slim screen head is thinner than many phones and makes home workspaces feel truly spacious. Add in the wedge stand's integrated phone holder and concealed cable management and L27e-30's user experience is profoundly clean and clutter-free. When reviewing documents late into the night, it's the little touches that make a big difference. For instance, the monitor's TÜV Rheinland Eye Comfortcertified technology filters harmful wavelengths to protect users' eyes from fatigue. And, once work is done, L27e-30 doubles as a great window into a world of entertainment. Take gameplay, where ghosting, streaking and torn images are a problem banished to history thanks to AMD FreeSync and a rapid 75 Hz refresh rate.
  • Functional & flattering
    With its brand new minimal restyling and 7.1 mm ultra-slim head, Lenovo L27e-30 looks as good in any home as the images it displays on its 27-inch In-Plane Switching panel screen. A screen that floats above its newly upgraded sculpted wedge stand that's engineered for elegance, stability and convenience because it tidies cables invisibly away behind its slender neck and integrates a rack to neatly hold a mobile phone.
  • Comfortable from any angle
    With its generous 27-inch In-Plane Switching panel display, L27e-30 delivers faultless images even when it's viewed from extreme angles as much as 178°. So, watching videos side-byside with someone at home, everyone sees the same picture with accurate, undistorted colors. And if users need to work at home, say, inputting data well into the night, this monitor safeguards their eyes from fatigue thanks to TÜV Rheinland Eye Comfort-certified technology that filters harmful blue wavelengths.
  • Convenience & control for work & entertainment
    Press play. And let the video coursework or entertainment flow uninterrupted.
Lenovo L27e-30 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Power Consumption (On mode)
17.5 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
Raven black
61.25 cm x 17.49 cm x 47.58 cm
4.53 kg
EMEA
CCC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, EU RoHS 2002/95/EC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, 3-sided bezeless, 3-side NearEdgeless
Raven black
61.25 cm x 17.49 cm x 47.58 cm - with stand
4.53 kg
HDMI , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m
EMEA
Security Slot Type
Kensington security slot
Input Voltage
17.5 W
17.5 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Lenovo Artery, Lenovo Display Control Center
Dimensions & Weight Details
With stand - width: 61.25 cm - depth: 17.49 cm - height: 47.58 cm - weight: 4.53 kg , Without stand - width: 61.25 cm - depth: 4.32 cm - height: 36.77 cm - weight: 3.6 kg
Shipping Width
71 cm
Shipping Depth
12.6 cm
Shipping Height
45.5 cm
Shipping Weight
6.35 kg
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DisplayPort
Brand: Lenovo
Stock Status: On Order
