Lenovo IdeaTab A3000 MediaTek MT8317 1GB 16GB 7" Android 4.2
Quicklinx: 91BMWS00 Mfr#: 59374512
  • Android 4.2 (Jelly Bean)
Stay connected wherever you are with the quad-core powered Lenovo IdeaTab A3000. Experience seamless switching between fast HSPA+ data when on the go (optional) and Wi-Fi when you reach your destination. At only 345gms , this mobile 7 inch Android tablet can easily be held in one hand. The IPS screen produces excellent screen colors and provides 178° visibility making it ideal for movies as well as reading text.
  • Quad-core performance
    The IdeaTab A3000's quad-core CPU accelerates performance and makes it perfect for virtually all forms of tablet gaming.
  • Complete connectivity
    Micro-USB for charging and connecting peripherals plus a micro-SD card slot for convenience and easy expandability.
  • USB OTG support
    USB OTG (On The Go) allows your tablet to charge and read other devices, such as USB memory sticks.
  • 7" HD display
    The IdeaTab A3000's HD display offers a clear and colorful viewing experience whether indoors or outside. The in-plane switching (IPS) screen delivers a wide viewing angle, perfect for sharing content with friends in groups.
  • Pocket size comfort
    The IdeaTab A3000 is a perfect size for reading, listening to music, and web-surfing - and it can easily slide into a pocket when not in use.
  • Comfortable design
    The A3000's "stripe" design emphasizes different tablet functions, while curved surfaces make it comfortable to hold.
Lenovo IdeaTab A3000 - tablet - Android 4.2 (Jelly Bean) - 16 GB - 7"
Tablet
Operating System
Display
7" IPS LED backlight - 1024 x 600 - Multi-Touch
MediaTek 8389 (Quad-Core)
Processor Clock Speed
1.2 GHz
Storage
16 GB
RAM
1 GB
Supported Flash Memory Cards
microSD
Wireless Connectivity
802.11b/g/n
Rear Camera
5 Megapixel
Front Camera
0.3 Megapixel
USB host
Battery Run Time
Up to 7 hours
12 cm x 1.1 cm x 19.4 cm
345 g
Slate black
1-year warranty
Tablet
Operating System
Display
7" IPS - LED backlight
Resolution
1024 x 600
Touchscreen
Multi-Touch
MediaTek 8389
1.2 GHz
Number of Cores
Quad-Core
Storage
16 GB
RAM
1 GB - LPDDR2 SDRAM
microSD
Communications
802.11b/g/n
Rear Camera
Sensor Resolution
5 Megapixel
Front Camera
Sensor Resolution
0.3 Megapixel
Multimedia
Audio
Stereo speakers
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x headset , 1 x Micro-USB
USB Host
3500 mAh
Run Time
Up to 7 hours
Run Time Details
Web browsing over Wi-Fi: up to 7 hours
Slate black
Sensors
Accelerometer, ambient light sensor, G-sensor
Volume control
12 cm
1.1 cm
19.4 cm
345 g
Limited warranty - 1 year - pick-up and return
