Lenovo IdeaPad Z570 i3-2310M 6GB 640GB 15.6 DVD-RW W7HP
Quicklinx: 7LTXWS00 Mfr#: M555EUK
  • Core i3
  • Microsoft Windows 7 Home Premium
  • IEEE 802.11n
  • DVD Rewriter
The trendy yet cost-effective IdeaPad Z570 is packed with loads of cool features to make your day more fun. Bring your multimedia experience alive on your high-definition widescreen display; optimize audio-visual settings with OneKey Theater II, and get top quality audio with SRS Premium Surround Sound. The IdeaPad Z570 is built for convenience too. The smart AccuType keyboard makes typing easier; and Energy Management features offer longer battery life.
You'll find rock-solid performance features - a powerful processor, spacious storage, and a thermal management system, which automatically adjusts fan speeds to keep you cool and your system quiet.
Immerse yourself in movies with a vibrant LED widescreen display. Create, edit, sync and share your home videos faster - and without additional pricey hardware - with Intel Quick Sync Video. So, whatever your idea of fun is, the IdeaPad Z570 will take you there.
  • Modern appeal
    An affordable Z series laptop is contemporary on the inside, sprinkling the interior with a comfortable AccuType keyboard and multi-touch touchpad. You'll find rock-solid performance features - a powerful processor, spacious storage, and a thermal management system, which automatically adjusts fan speeds to keep you cool and your system quiet.
  • Entertain in style
    Command your entertainment experience with the OneKey Theater button, which enhances components like SRS Premium Sound. Immerse yourself in movies with a vibrant LED widescreen display. Create, edit, sync and share your home videos faster - and without additional pricey hardware - with Intel Quick Sync Video.
  • Detach yourself
    Say goodbye to the constraints of plugs and cables. Manage your wireless connections with Lenovo's ReadyComm utility. No matter how you relish in your laptop freedom, your battery will be along for the ride thanks to Lenovo's Energy Management software.
Lenovo IdeaPad Z570 1024 - 15.6" - Core i3 2310M
Notebook
Intel Core i3 2310M / 2.1 GHz
DDR3
Display
15.6" LED backlight 1366 x 768 / WXGA
802.11b/g/n
6-cell
37.6 cm 3.6 cm
Environmental Standards
ENERGY STAR Qualified
Notebook
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3
64-bit Computing
Chipset
Mobile Intel HM65 Express
Hyper-Threading Technology, integrated memory controller
DDR3 SDRAM
Speed
1333 MHz
SO-DIMM 204-pin
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (WXGA)
Widescreen
Image Aspect Ratio
16:9
Audio & Video
Sound
Microphone
Codec
Realtek ALC272
High Definition Audio
Input
Keyboard, touchpad
Multi-touch touchpad
Communications
Wireless
802.11b/g/n
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
6-cell Lithium Ion
Installed Qty
1
Max Supported Qty
1
AC Adapter
Input
Connections & Expansion
Memory Card Reader
5 in 1 (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard)
Security lock slot (cable lock sold separately), hard drive password
Localization
37.6 cm 3.6 cm
ENERGY STAR Certified
