Lenovo IdeaPad Y510p Intel Core i7-4700MQ 12GB 1TB 15.6" Windows 8 64-bit
Quicklinx: 9BJ2WS00 Mfr#: 59396009
  • Core i7
  • Windows 8 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
This laptop puts some serious power behind your multimedia – whether games, movies, or music. Premium graphics, audio, and processing technology add that extra boost to whatever entertainment you have queued up, and the unique, interchangeable Ultrabay lets you upgrade instantly.
  • Ultrabay
    Dial up your laptop's performance with this interchangeable bay that can be instantly swapped out for dual graphics capability, increased storage space or an additional fan for cooling.
  • Intelligent touchpad
    Optimized for the Windows 8 interface, the intelligent touchpad enables easy scroll, zoom and rotate functions for comfortable control of your laptop.
  • NVIDIA GeForce graphics with optional dual graphics card support
    Standard with up to NVIDIA GeForce graphic, this laptop lets you add a second card with NVIDIA SLI technology using the Ultrabay to generate up to 1.6 times more frame rate performance.
  • Premium JBL speakers with Dolby Home Theater v4
    Increased audio clarity and maximized volume output without distortion - enjoy a crisp, clear immersive surround sound experience over built-in JBL -designed stereo speakers or your own headphones.
  • S/PDIF support
    If you opt for digital sound output, you can rely on Sony/Philips Digital Interconnect Format (S/PDIF) to minimize audio loss.
  • Cool-touch metal design
    The brushed-metal exterior and metal speaker grilles give this laptop a high-performance look and feel to match the powerful components inside.
  • Backlit Accutype keyboard
    The AccuType keyboard boasts a modern look and feel with flatter, slightly curved keys that improve your comfort while increasing typing accuracy. And the standard backlighting makes typing easy in low-light conditions.
  • Always-on USB port
    Recharge a mobile device even when the laptop is powered off and unplugged.
  • Integrated 720p HD webcam and dual digital array microphones
    Crystal-clear video and audio, plus face-tracking, will help you chat with friends and family like you're really there.
  • Lenovo cloud storage
    Protect your critical data, while also making access to information and file-sharing quick and convenient. Automatically back-up and synchronize data across your home, while enabling access from multiple devices. Data is encrypted on transfer, for an extra level of security.
  • Fast data transfer
    Move data quickly between your laptop and other devices with USB 3.0, which enables up to ten times faster file transfer - allowing for lightning-fast copying of large media files as well as seamless connections between audio- and video-related peripherals. Or share your data wirelessly via optional Bluetooth.
Lenovo IdeaPad Y510p - 15.6" - Intel Core i7 - 4700MQ - 12 GB RAM - 1 TB Hybrid Drive - QWERTY UK
Notebook
Operating System
Win 8 64-bit - English
Intel Core i7 (4th Gen) - 4700MQ / 2.4 GHz (3.4 GHz) / 6 MB Cache
12 GB DDR3L (1 x 8 GB + 1 x 4 GB)
Storage
1 TB Hybrid Drive (8 GB flash)
Optical Drive
DVD-Writer / Blu-ray
Display
15.6" LED backlight VibrantView 1366 x 768 / HD
Graphics
NVIDIA GeForce GT 750M
Video Memory
2 GB GDDR5 SDRAM
Keyboard
QWERTY UK
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
6-cell - up to 5 hours
Dusk black
38.7 cm x 25.9 cm x 3.58 cm
2.7 kg
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 8 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (4th Gen) 4700MQ / 2.4 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel HM86
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0
RAM
12 GB (1 x 8 GB + 1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
1 TB Hybrid Drive SATA 3Gb/s (8 GB flash)
Optical Drive
DVD-Writer / BD-ROM removable
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
VibrantView, glossy
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Audio Features
Output: JBL
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
QWERTY UK
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Network Interface
Gigabit Ethernet
6-cell Lithium Ion
62 Wh
Run Time
Up to 5 hours
AC Adapter
Input
Output
120 Watt
Connections & Expansion
Expansion Bays
1 x Ultrabay
2 x USB 3.0 , USB 2.0 , HDMI , LAN , VGA , Microphone input , Headphone/SPDIF combo jack
Memory Card Reader
6 in 1 (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Microsoft Office 2013 (Trial)
Dusk black
Security lock slot (cable lock sold separately), "Always On" USB port
Power adapter
RoHS
2.7 kg
