The IdeaPad Slim 3 Chromebook is perfect for school, social media, browsing, and streaming. It's thin and light for easy traveling, with 13.5 hours of battery life and the formidable power of MediaTek Kompanio 500 Series processors. It has everything you need with stability and security, navigate smoothly through tasks all day long. And front-facing Waves-tuned speakers deliver impressive audio.
Get your groove on all day, every day
Balancing work and play all day is a pleasure with the freedom of the 13.5-hour battery life. Life on the go has never felt so grounded. You can run multiple browsing tabs seamlessly, thanks to the power of MediaTek Kompanio 500 Series processors, housed in a solid fanless chassis. WiFi 6 delivers stable signal strength with fast up and download speeds for sharing. And the optional 14? touchscreen display makes organizing your files and media effortless. -
Blurs the line between work and play
Whether you're catching up with your favorite show, checking out YouTube, or attending virtual classes, the 14? FHD display provides a fantastic viewing experience. The IPS display with 100% sRGB colour gamut is crisp and rich with vivid clarity and vibrant contrast that holds even from a wide viewing angle. An anti-glare coating makes reflections a non-issue and Waves-tuned audio through two forward-facing Maxx Audio speakers complements the visuals with great sound quality. -
Privacy is calling
Keep your conversations secure and private with a privacy shutter built into the FHD camera and a mute mic key. Make video calls that are crystal clear via FHD while the dual mike array eliminates distracting background noise. When you're done calling, close the built-in camera shutter manually to secure an extra layer of privacy. -
A PC made responsibly
The ENERGY STAR-rated and EPEAT Gold-registered* IdeaPad Slim 3 Chromebook features battery material built with 30% post-consumer recycled plastic, plus 30% ocean-bound plastic in the system bag. And through the CO 2 Offset Service, you can also offset the estimated carbon emission linked to your PC over its average lifecycle by supporting projects aimed to help offset CO 2 emitted in the atmosphere.
- Lenovo IdeaPad Slim 3 Chrome 14M868 - 14" - MediaTek Kompanio 520 - 4 GB RAM - 128 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- MediaTek Kompanio 520 2.05 GHz
- Memory
- 4 GB LPDDR4X (provided memory is soldered)
- Storage
- 128 GB eMMC
- Display
- 14" 1920 x 1080 / Full HD
- Graphics
- ARM Mali-G52 2EE MC2
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.3
- Battery
- Up to 13.5 hours
- Security
- Google Security Chip H1
- Abyss blue
- 32.59 cm x 22.18 cm x 1.86 cm
- 1.3 kg
- Localisation
- Manufacturer Selling Program
- Lenovo TopSeller
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 260 kg carbon emissions
- Limited warranty - 1 year - pick-up and return
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Number of Cores
- 8-core
- Integrated memory controller
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR4X SDRAM
- Speed
- 3733 MHz
- Rated Speed
- 1866 MHz
Storage
- Main Storage
- 128 GB eMMC - eMMC 5.1
Display
- 14" - TN
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Horizontal Viewing Angle
- +45 / -45
- Vertical Viewing Angle
- +15 / -35
- Colour Gamut
- 45% NTSC
- Anti-glare
Audio & Video
- Graphics Processor
- ARM Mali-G52 2EE MC2 - up to
- Max Monitors Supported
- 1 external monitor(s)
- Camera
- Yes - 1080p
- Camera Features
- Privacy shutter, fixed focus
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio, Waves MaxxAudio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad, Chrome keyboard
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Dual stream (2x2)
- Technology
- Lithium polymer
- Capacity
- 47 Wh
- Run Time
- Up to 13.5 hours
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- USB 3.2 Gen 1 , USB-C 3.2 Gen 1 (supports DisplayPort 1.1a Alt Mode) (Power Delivery 3.0) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Abyss blue
- Case Material
- Polycarbonate ABS (bottom), polycarbonate ABS (top), 15% Talc (top), 15% Talc (bottom)
- Surface Finish
- Texture painting
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- RoHS, Energy-Related Products (ErP) Lot 6, Energy-Related Products (ErP) Lot 26
- Localization
- Lenovo TopSeller
- 1.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- 5 °C
- 35 °C
- 8 - 95%
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
Lenovo 65W USB-C DC Travel Adapter | In Stock | £41.22 |
Lenovo ThinkPad Basic Topload - Notebook carrying case - 15 | In Stock | £13.44 |
Lenovo Casual Toploader T210 - Notebook carrying case 15.6" Black | In Stock | £15.54 |
Lenovo LENOVO 2-IN-1 LAPTOP STAND | In Stock | £29.52 |
Lenovo CASE_BO LENOVO SELECT 14-INCH SLEEVE | In Stock | £17.71 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo Depot Repair - Extended service agreement - parts and | In Stock | £52.27 |
Other bundles (11)
Lenovo HDMI to VGA Monitor Adapter | In Stock | £22.97 |
Lenovo 2m HDMI Cable | In Stock | £16.94 |
Lenovo Professional Wireless Keyboard | In Stock | £52.98 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.01 |
Lenovo Essential Compact Wireless Mouse | In Stock | £13.76 |
Lenovo USB-C To USB-C Cable - 2m | In Stock | £31.47 |
Lenovo Hybrid USB-C to USB-C Cable with USB-A Adaptor 1m | In Stock | £23.23 |
Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed | In Stock | £23.78 |
Lenovo Stereo 3.5mm Headset | In Stock | £18.05 |
Lenovo USB-C Cable 1M | In Stock | £15.73 |
Lenovo ThinkPad Essential Wireless Mouse | In Stock | £13.44 |
