Product
Lenovo IdeaCentre 310 AIO Intel Celeron J3355 4GB 1TB 19.5" Win 10
Clearance
Quicklinx: D4GDWS00 Mfr#: F0CL003AUK#SP
  • Bluetooth 4.0
  • Celeron
  • IEEE 802.11n
Sorry but this product has been discontinued.
View used stock
Slim, stylish, and simple to use, the IdeaCentre AIO 310 will make a welcome addition to any home. Great visuals and sound enhance your everyday computing tasks, and they're powered by reliable processors. Spreadsheets, email, and multimedia will be simple and dependable - and they'll look and sound great.
  • Easy, clutter-free setup with one cable
    Needing only a single power cable and no other wires, this AIO is ready to use right out of the box. Easily work, watch videos, play games, or video chat on a crisp display and integrated camera with microphone. You'll be ready to start as quickly as you can plug it in.
  • Great sound for great fun
    Not only does the Lenovo 310 features a beautiful display, it has integrated stereo speakers. Turn on this PC and you are immediately ready to enjoy all your media. The Lenovo 310 is ready to entertain, whether it be your favorite movie or song.
  • Built to perform for years
    The Lenovo 310 features powerful processors, spacious memory, and integrated graphics for well-rounded performance. Perfect for daily use, whether browsing the Internet, catching up on emails, or shopping, this AIO works with your routine - and will continue to do so.
Lenovo 310-20IAP - all-in-one - Celeron J3355 2 GHz - 4 GB - 1 TB - LED 19.5"
Personal computer - all-in-one
1 x Intel Celeron J3355 / 2 GHz (2.5 GHz) (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
4 GB (installed) / 4 GB (max) - DDR3L SDRAM
Storage Controller
SATA
Hard Drive
1 x 1 TB - SATA 6Gb/s - 5400 rpm
Optical Storage
DVD SuperMulti
Monitor
19.5" - LED - 1440 x 900 (WXGA+) - 16:10
Graphics Controller
Intel HD Graphics 500
Camera
GigE, 802.11b, 802.11a, 802.11g, 802.11n, Bluetooth 4.0, 802.11ac
46.1 cm x 3.7 cm x 37.6 cm
3.09 kg
Personal computer
Product Form Factor
All-in-one - with frame stand
Built-in Devices
Stereo speakers
Processor / Chipset
CPU
Max Turbo Speed
2.5 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 4 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
SO-DIMM 204-pin
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
DVD SuperMulti - SATA
Monitor
Monitor Type
LED - IPS
Diagonal Size
19.5"
Native Resolution
1440 x 900 (WXGA+)
Widescreen Display
Image Aspect Ratio
16:10
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Audio Output
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
720p
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Lenovo Calliope Keyboard
USB
Mouse
Mouse Name
Lenovo Calliope Mouse
Optical
USB
Audio Input
Microphone
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
1 x headphones/microphone , 1 x LAN , 1 x USB 3.0 (1 in front) , 2 x USB 2.0 , 1 x HDMI
Power adapter
Nominal Voltage
Power Provided
45 Watt
46.1 cm
3.7 cm
37.6 cm
3.09 kg
10 °C
35 °C
10 - 90%
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D4GD 037526
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £321.21
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
