The 20 cm HDMI to VGA adapter provides the best sleek compatibility experience as it seamlessly enables interoperability of ThinkPad systems with commercial analog projectors and displays. The small form factor HDMI to VGA adapter allows you to connect to an extended display or work in mirrored mode with VGA projectors.
                Versatile ConnectivityThis Lenovo video adapter offers a seamless bridge between HDMI and VGA interfaces, allowing users to connect their HDMI-enabled devices to VGA-compatible displays and projectors. The adapter ensures that users can enjoy high-quality video output regardless of the display technology they are using.
                Durable DesignCrafted with a robust build, the adapter features a 19-pin HDMI Type-A male connector on one end and a 15-pin HD D-Sub (HD-15) female connector on the other. This design not only ensures a secure connection but also ensures the adapter's longevity and reliability for all your presentation and entertainment needs.
- Lenovo adapter - HDMI / VGA - 20 cm
- Cable
- Adapter - HDMI / VGA
- Length
- 20 cm
- Connector
- HDMI - male
- Connector (Second End)
- HD-15 (VGA) - female
- Cable Type
- Adapter
- Interface Supported
- HDMI / VGA
- Length
- 20 cm
- Connector
- 19 pin HDMI Type A - male
- 15 pin HD D-Sub (HD-15) - female
