Lenovo HDMI to VGA Monitor Adapter
Quicklinx: C2XYWS00 Mfr#: 0B47069
Length: 20cm
More than 50 In Stock
£23.09 ex VAT
£27.70 inc VAT
The 20 cm HDMI to VGA adapter provides the best sleek compatibility experience as it seamlessly enables interoperability of ThinkPad systems with commercial analog projectors and displays. The small form factor HDMI to VGA adapter allows you to connect to an extended display or work in mirrored mode with VGA projectors.
  • Versatile Connectivity
    This Lenovo video adapter offers a seamless bridge between HDMI and VGA interfaces, allowing users to connect their HDMI-enabled devices to VGA-compatible displays and projectors. The adapter ensures that users can enjoy high-quality video output regardless of the display technology they are using.
  • Durable Design
    Crafted with a robust build, the adapter features a 19-pin HDMI Type-A male connector on one end and a 15-pin HD D-Sub (HD-15) female connector on the other. This design not only ensures a secure connection but also ensures the adapter's longevity and reliability for all your presentation and entertainment needs.
Lenovo adapter - HDMI / VGA - 20 cm
Cable
Adapter - HDMI / VGA
Length
20 cm
Connector
HDMI - male
Connector (Second End)
HD-15 (VGA) - female
Cable Type
Adapter
Interface Supported
HDMI / VGA
Length
20 cm
Connector
19 pin HDMI Type A - male
15 pin HD D-Sub (HD-15) - female
Length: 20cm
Brand: Lenovo
