Lenovo G770 is an affordable way to tackle your everyday computer tasks. It has all the essentials, whether you're trying to do homework, complete the family budget, surf the web, send an e-mail or just play a little. A powerful processor, high-capacity storage, plenty of memory and Lenovo Enhanced Experience 2.0 with RapidBoot technology make it fast and efficient. Cool design features, brilliant HD widescreen and powerful, switchable graphics make it fun to look at. And additional Lenovo apps and systems make it easy to connect, use and keep secure.
Affordable product, high-price performance
This laptop is an affordable way to tackle your everyday computer tasks. It has all the essentials, whether you're trying to do homework, complete the family budget, surf the web, send an e-mail or just play a little. A powerful processor, high-capacity storage, plenty of memory and Lenovo Enhanced Experience 2.0 with RapidBoot technology make it fast and efficient. Cool design features, brilliant HD widescreen and powerful, switchable graphics make it fun to look at. And additional Lenovo apps and systems make it easy to connect, use and keep secure. -
Stress-free use
Versatile and durable, this G Series laptop includes plenty of features to facilitate a regular, stress-free computing experience. High-speed 802.11n Wi-Fi provides fast connectivity, Lenovo ReadyComm helps you easily manage your networking and Internet connection, and Lenovo DirectShare allows you to synchronize your files with another notebook without having to connect to the Internet. VeriFace face recognition is a fun and secure way to login to your PC. Lenovo Energy Management uses advanced energy-saving technology to stretch your battery life, protecting your battery's long-term durability and increasing the amount of time you can go unplugged. And you can rest at ease knowing OneKey Rescue System is there to simplify data backup and recovery, allowing you to focus on using your computer instead of worrying about its maintenance. -
Attractive design
Enjoy the brushed-metal appearance of the G770, then open the one-hand hinge with ease and take a gander inside. The brushed-metal palm rest cover is stunning to behold and cool to the touch, while the popular AccuType keyboard is a thing of beauty. It features island-style, easy-to-press keys with finger-friendly design and an ergonomic spacebar for safe, comfortable use - which is good, considering how much time you're going to want to spend using your new laptop.
- Lenovo G770 - 17.3" - Core i3 2310M - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Home Premium 64-bit
- Processor
- Intel Core i3 (2nd Gen) 2310M / 2.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR3 (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD-Writer
- Display
- 17.3" LED backlight 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 3000
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, 10/100 Ethernet
- Battery
- 6-cell
- Dark brown
- 41.6 cm x 27.2 cm x 4.5 cm
- 3 kg
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- Localisation
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Home Premium 64-bit Edition
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM65 Express
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3 SDRAM
- Speed
- 1333 MHz / PC3-10600
- Rated Speed
- 1333 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD-Writer fixed
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- Glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Dynamic Video Memory Technology 5.0
- Camera
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Numeric Keypad
Communications
- Wireless
- 802.11b/g/n
- Network Interface
- 10/100 Ethernet
- Technology
- 6-cell Lithium Ion
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- 4 x USB 2.0 , VGA , HDMI , LAN , Headphone output , Microphone input
- Memory Card Reader
- 5 in 1 (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card)
Software
- Software Included
- Microsoft Office 2010 Starter
- Dark brown
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password
- RoHS
- Localization
- 3 kg
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
