Lenovo G27-30 27" FHD 165Hz 1ms Gaming Monitor
Quicklinx: GWXHWS00 Mfr#: 66E7GAC2UK
When it comes to performance, Lenovo G27-30's got game. Let's start with a look at its 27-inch 1,920 x 1,080 Full HD resolution display that delivers startlingly life-like lighting effects to gameplay in a luminous 3500 cd/m², thanks to HDR decoding on-the-fly. It never misses a beat, even in the most intense moments, because its speedy 165Hz refresh rate and 1ms MPRT response time, coupled with AMD FreeSync Premium, remove image stutter, break, tear and streak from the experience, leaving a smooth session.
Besides, the 99% sRGB color gamut display featuring true 8-bit color will make your gameplay impressive for sure. And, as bright as this display is, users can watch comfortably because TÜV Rheinland Low Blue Light technology can protect eyes from blue light harm on a sliding scale, as well as cut out screen flicker. All these enhance your viewing pleasure plus a vastly reduced chance of eye fatigue.
Lenovo G27-30 - LED monitor - Full HD (1080p) - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1103476
Energy Class
Class E
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Pixel Pitch
0.311 mm
Brightness
350 cd/m²
Contrast Ratio
3000:1 / 3000000:1 (dynamic)
Response Time
1ms (MPRT), 4 ms (Level 4), 5 ms (Level 3), 6 ms (Level 2), 7 ms (Level 1)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB, 90% DCI-P3
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
Dimensions (WxDxH) - with stand (lowest position)
61.41 cm x 23.92 cm x 39.44 cm
5.8 kg
English / United Kingdom
CCC, CEE Tier 1, EU RoHS 2002/95/EC, TUV Eye Comfort certified, TUV Eyesafe Display Certification, TUV Rheinland Low Blue Light (Hardware Solution)
3-year warranty
Display Type
Energy Class
Class E
Energy Class (HDR)
Class G
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
81.72
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
3-side NearEdgeless, 8-bit(6-bit + FRC) Colour Depth, HDR decoding
Raven black
61.41 cm x 23.92 cm x 39.44 cm - with stand (lowest position)
5.8 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
DisplayPort 1.4 , 2 x HDMI , Audio line-out (mini-jack)
Mechanical
Height, tilt
Tilt Angle
-5/+22
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
Screws
1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
21.5 kWh/1000h
Power Consumption HDR (On mode)
29.7 kWh/1000h
Power Consumption (Typical)
21 Watt
Power Consumption (Max)
52 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Lenovo Artery
Dimensions & Weight Details
With stand (lowest position) - width: 61.41 cm - depth: 23.92 cm - height: 39.44 cm - weight: 5.8 kg , With stand (highest position) - width: 61.41 cm - depth: 23.92 cm - height: 52.9 cm - weight: 5.8 kg , Without stand - width: 61.41 cm - depth: 4.5 cm - height: 36.98 cm - weight: 3.9 kg
Shipping Width
70.3 cm
Shipping Depth
19 cm
Shipping Height
42.2 cm
Shipping Weight
7.6 kg
Limited warranty - 3 years
