Experience the thrill of intense E-sports games on the uber-cool Lenovo G25-20 monitor. With its 24.5-inch screen, the ideal size for gaming, the G25-20 ensures all the breathtaking action happens right in front of you. An ultra-fast 1ms GtG response time with up to 0.8ms MPRT, and an impressive refresh rate of 165 Hz go hand in hand with AMD FreeSync Premium technology to ensure smooth, consistent display with no lags, motion blur, tearing, or stuttering. High Dynamic Range (HDR) decoding with 400-nit brightness allows for incredible lifelike colors and sharp contrasts, letting you smoothly maneuver lightning-fast games. While you are at it, the exclusive Lenovo Artery software offers special gaming functions that let you swiftly optimize display settings to cut through competition in the nick of time.
- Lenovo G25-20 - LED monitor - Full HD (1080p) - 25"
- LED-backlit LCD monitor - 25"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/692590
- Energy Class
- Class E
- Adaptive-Sync Technology
- AMD FreeSync Premium
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 165 Hz
- Pixel Pitch
- 0.2832 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 0.8ms (MPRT), 1ms (level4, 2ms (level3), 3ms (level2), 4ms (level1), 5ms (off)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931)
- Input Connectors
- 2xHDMI, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Raven black
- 55.75 cm x 23.48 cm x 36.78 cm
- 5.5 kg
- Localisation
- English / United Kingdom
- CCC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, EU RoHS 2002/95/EC
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 25"
- Viewable Size
- 24.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2832 mm
- Pixel Per Inch
- 90
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Integrated cable management, 8-bit Colour Depth, 3-side NearEdgeless, HDR decoding
- Raven black
- 55.75 cm x 23.48 cm x 36.78 cm - with stand
- 5.5 kg
- 2 x HDMI , DisplayPort , Audio line-out
Mechanical
- Height, tilt
- Tilt Angle
- -5/+22
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 17.8 kWh/1000h
- Power Consumption (Typical)
- 18 Watt
- Power Consumption (Max)
- 27 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Included Software
- Lenovo Artery, Lenovo Display Control Center
- OS Required
- Microsoft Windows 7 / 10
- Dimensions & Weight Details
- With stand (lowest position) - width: 55.75 cm - depth: 23.48 cm - height: 36.78 cm - weight: 5.5 kg , With stand (highest position) - width: 55.75 cm - depth: 23.48 cm - height: 49.78 cm - weight: 5.5 kg , Without stand - width: 55.75 cm - depth: 4.93 cm - height: 33.35 cm
- Shipping Width
- 40.5 cm
- Shipping Depth
- 62 cm
- Shipping Height
- 18.6 cm
- Shipping Weight
- 6.8 kg
- Limited warranty - 3 years
