Lenovo G24e-20 23.8" FHD 100Hz 1ms Gaming Monitor
Quicklinx: GWXDWS00 Mfr#: 66D7GAR1UK
With the Lenovo G24e-20 in your arsenal, dominate every game with extraordinary ease. A large screen, and a three-side NearEdgeless VA display offer stunning clarity, giving you a quick-footed advantage whenever you are embroiled in fast-paced games.
Players can focus on the game and successfully work out their game plan, thanks to AMD FreeSync Premium technology, a 100 Hz refresh rate that you can overclock to 120 Hz, and super-fast 1ms MPRT that virtually eliminate screen tearing and input delay. Moreover, with 95% sRGB color gamut and 3000:1 contrast ratio, you get to enjoy uncompromised color performance for light work and entertainment. Natural Low Blue Light technology protects your eyes while keeping colors accurate. There is no color distortion, unlike the low blue light software solution that makes the visual appear yellowish. Everything to ensure you are well-equipped when going for the win.
  • A brilliant view for work and play
    The Lenovo G24e-20 display blends economy with uncompromising performance and compelling visuals. The adjustable monitor comes with Natural Low Blue Light technology, which prevents image distortion and reduces eyestrain so you can keep on playing, working, and streaming in comfort. The 3000:1 contrast ratio displays more gray levels than standard for vivid imagery and stunning video output that gamers crave. 95% sRGB color gamut offers a wider selection of colors that allows you to see exactly what the developer intended and enhances the gaming experience.
  • Equipped for everyday gaming
    Loaded with multiple gaming features, the G24e powers uncompromising gaming with stunning display performance. The 100 Hz refresh rate that can overclock to 120 Hz, along with 1ms MPRT ensure latency, streaking, and ghosting are kept to a minimum for instantaneous, high-quality gaming and content consumption. AMD Freesync Premium technology helps reduce screen stutter for significantly smoother gameplay by dynamically adjusting the refresh rate to match the GPU output, so you can always stay focused on the game.
  • Ideal comfort and control
    The V-shaped base looks stylish while providing excellent ergonomic support, facilitating an enjoyable viewing experience. The display supports both HDMI 2.0 and DisplayPort 1.2 PC-to-monitor connectivity.
Lenovo G24e-20 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class F
Adaptive-Sync Technology
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.2745 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 3000000:1 (dynamic)
Response Time
1ms (MPRT), 4 ms (Level 4), 5 ms (Level 3), 6 ms (Level 2), 7 ms (Level 1)
Colour Support
16.7 million colours
Colour Gamut
95% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
53.98 cm x 18.47 cm x 40.86 cm
3.9 kg
English / United Kingdom
CCC, CEE Tier 2, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, EU RoHS 2002/95/EC, TUV Eyesafe Display Certification, TUV Hardware Low Blue Light Certification
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
95% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, 8-bit Colour Depth, 3-side NearEdgeless
Raven black
53.98 cm x 18.47 cm x 40.86 cm - with stand
3.9 kg
HDMI , DisplayPort 1.2 , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
20 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption (Max)
25 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Lenovo Artery, Lenovo Display Control Center
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand (lowest position) - width: 53.98 cm - depth: 18.47 cm - height: 40.86 cm - weight: 3.9 kg , With stand (highest position) - width: 53.98 cm - depth: 18.47 cm - height: 40.86 cm - weight: 3.9 kg , Without stand - width: 53.98 cm - depth: 4.4 cm - height: 32.57 cm - weight: 3.2 kg
Shipping Width
63.5 cm
Shipping Depth
40.5 cm
Shipping Height
12.4 cm
Shipping Weight
5.9 kg
Limited warranty - 3 years
