The Lenovo Essential Compact mouse is designed with your convenience in mind. It's easy to get more done when you don't have to waste time untangling messy cables or searching the office for other batteries. Its compact size makes it the perfect companion no matter what the occasion.
Wireless convenience
Experience the freedom of movement with the Lenovo Essential Compact mouse's wireless connectivity technology. Its 2.4 GHz interface ensures a reliable connection without the clutter of cables. -
Designed for everyone
This mouse is thoughtfully designed for both right- and left-handed users, offering comfort and ease of use regardless of your dominant hand. Its ambidextrous orientation makes it a versatile choice for any user. -
Precision control
Navigate with ease and accuracy thanks to the mouse's 1000 DPI movement resolution. The two-way scrolling wheels enhance your browsing experience, allowing for smooth and precise document navigation and web browsing.
 - Lenovo Essential Compact - mouse - 2.4 GHz - black
 - Mouse
- Connectivity Technology
 - Wireless - 2.4 GHz
 - Black
- Orientation
 - Right and left-handed
 - 5.6 cm x 9.8 cm x 3.2 cm
 - 50 g
- Wireless Receiver
 - USB wireless receiver
- Buttons Qty
 - 3
- Movement Resolution
 - 1000 dpi
 - Scrolling wheels (2-way), Nano wireless receiver
- Battery
 - AA type
- Package Type
 - OEM
 - 1-year warranty
 - Mouse
- Wireless Receiver
- Orientation
 - 5.6 cm
 - 9.8 cm
 - 3.2 cm
 - 50 g
 - Black
Input Device
 - Wireless
- Interface
 - 2.4 GHz
- Buttons Qty
 - 3
 - 1000 dpi
 - 1 x USB - 4 pin USB Type A
- Included Accessories
 - 1 AA battery
 - ANATEL, CB, CITC, CONATEL, cTUVus, ETA, FCC, IC, ICASA, ICT, iDA, IFETEL, MIC, NCC, NTC, sDoC, SDPPI, SIRIM, SRRC, Subtel, TRA, TUV, VCCI
- Package Type
 - OEM
 - AA type
- Run Time (Up To)
 - 12 months
 - Limited warranty - 1 year
 - 0 °C
 - 32 °C
 - 10 - 90%
