Lenovo DisplayPort Adapter - DisplayPort (M) to DisplayPort (F)
Quicklinx: BZZNWS00 Mfr#: 0B47092
£66.79 ex VAT
£80.14 inc VAT
Lenovo DisplayPort to Dual DisplayPort Adapter provides multi-monitoring at its finest without the use of an expensive graphics card. The two modes supported are Expanded mode and Mosaic mode. In Expanded mode, one ThinkCentre DisplayPort can be connected to two identical monitors with one DisplayPort to Dual DisplayPort Adapter and two Options DisplayPort cables (0A36537). In Quad Mosaic mode, two ThinkCentre DisplayPorts can be connected to four identical monitors with two DisplayPort to Dual DisplayPort Adapters and four DisplayPort cables. Maximum resolution supported in Quad Mosaic mode is 3840 x 2160.
  • Versatile connectivity
    This Lenovo DisplayPort adapter offers a male 20 pin DisplayPort connector on one end and two female 20 pin DisplayPort connectors on the other, enabling flexible connection options for a variety of PC setups.
  • Enhanced compatibility
    Designed with PC compatibility in mind, this adapter ensures seamless integration with your existing hardware, providing a reliable solution for extending or mirroring your display.
DisplayPort adapter
Connector
DisplayPort - male
Connector (Second End)
2 x DisplayPort - female
ThinkCentre M700; M70c; M70q; M70s; M70t; M710s; M720e; M720q; M720s; M720t; M75q-1; M75s Gen 2; M75s-1; M75t Gen 2; M800; M80s; M80t; M90s; M90t; M920q; M920t; M93p; M93z; ThinkEdge SE30; SE50; ThinkStation P330; P330 Gen 2; P350
DisplayPort adapter
Connector
20 pin DisplayPort - male
2 x 20 pin DisplayPort - female
Lenovo ThinkCentre M700 , Lenovo ThinkCentre M70c 11GJ, 11GK, 11GL, 11GM , Lenovo ThinkCentre M70q 11E7, 11E8 , Lenovo ThinkCentre M70s 11DB, 11DC, 11EW, 11EX , Lenovo ThinkCentre M70t 11D9, 11DA, 11EU, 11EV , Lenovo ThinkCentre M710s , Lenovo ThinkCentre M720e 11BE , Lenovo ThinkCentre M720q 10U9 , Lenovo ThinkCentre M720s 10U7 , Lenovo ThinkCentre M720t 10U5 , Lenovo ThinkCentre M75q-1 11A4, 11A5, 11A7 , Lenovo ThinkCentre M75s Gen 2 11R7, 11R8, 11R9, 11W1 , Lenovo ThinkCentre M75s-1 11A9, 11AA, 11AV, 11AW , Lenovo ThinkCentre M75t Gen 2 11RB, 11RC, 11RD, 11W5, 11W6 , Lenovo ThinkCentre M800 , Lenovo ThinkCentre M80s 11CU, 11CV, 11EM, 11EN , Lenovo ThinkCentre M80t 11CS, 11CT, 11EK, 11EL , Lenovo ThinkCentre M90s 11D1, 11D2, 11D6, 11D7 , Lenovo ThinkCentre M90t 11CY, 11D0, 11D4, 11D5 , Lenovo ThinkCentre M920q 10RR, 10RS, 10RT, 10RU, 10SY, 10T1 , Lenovo ThinkCentre M920t 10U1 , Lenovo ThinkCentre M93p , Lenovo ThinkCentre M93z , Lenovo ThinkEdge SE30 11NC, 11NJ , Lenovo ThinkEdge SE50 11RJ , Lenovo ThinkStation P330 30CG , Lenovo ThinkStation P330 Gen 2 , Lenovo ThinkStation P350 30E3, 30E4, 30E5, 30E6
