Lenovo B50-50 80s2 Core i3-5005U 15.6" 4GB 500GB Windows 10 Home 64-bit
Quicklinx: CFFCWS00 Mfr#: 80S2004AUK
  • Core i3
  • Bluetooth 4.0
  • IEEE 802.11n
Up to 5th Generation Intel® Core™ Processors
The new standard for PC performance has arrived with Intel® 6th Gen Core™ processors. This blazing fast, feature-packed processor family with built-in security is ready to take your productivity, creativity, and 3D gaming to the next level. What's more, by enabling the exciting Windows 10 features, 6th Gen Intel Core processors empower you to unleash your imagination and explore the possibilities.
Up to Windows 10 Home
Windows 10 Pro is designed to empower you and your business. It allows you to do great things across your devices securely with anyone, anywhere, and at any time. Fitting a variety of budgets, it's also very easy to use. So you can get more done right from the start.
Comfortable Viewing
The HD anti-glare display helps reduce eye fatigue, allowing you to work longer in comfort.
Thin and Light Design
Starting at a mere 2.3kg and just 22.9mm thick, the Lenovo B50 laptop is ready for productivity on the go.
Extra Peace of Mind
You can rest assured knowing your hardware is protected, thanks to the Kensington® Minisaver Cable Lock.
Connectivity Options
With 802.11 bgn WiFi and optional Bluetooth® 4.0, you can connect to the Internet wherever you go.
Integrated Webcam
The 0.3M webcam and microphone will help you enjoy web conferences or online video chats like you're really there.
Fast Data Transfer
Move data between the Lenovo B50 and other devices quickly with USB 3.0. Up to ten times faster than previous USB technologies, it's also backward-compatible.
Ample Storage
With storage up to 1TB HDD, you won't have to worry about where to put all your data, videos, music, and photos.
HDMI Port
Stream content quickly and easily from your Lenovo B50 to a television or other display.
  • Thin and light
    Thinner than 1" and small starting weight, it is easy to carry around.
  • Great performance
    Enjoy the power of the efficient processor, discrete graphics and more.
  • 15.6" widescreen display
    The display delivers bright, crisp visuals in HD resolution.
  • Enhanced graphics
    With advanced graphics technology, you'll enjoy stunning visuals.
  • Fast data transfer
    Move data between the B50 and other devices quickly with USB 3.0.
  • HDMI output
    Easily connect to your TV or monitor for large-screen high-definition viewing.
  • Swift connectivity
    With 802.11 b/g/n Wi-Fi connectivity and Bluetooth 4.0, you'll be able to connect to the Internet wherever you go.
  • Integrated webcam
    The webcam helps to make your web conferences or online video chats a breeze.
Lenovo B50-50 - 15.6" - Intel Core i3 - 5005U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Home 64-bit - English
Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Keyboard
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
4-cell
37.8 cm x 26.5 cm x 2.29 cm
2.3 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Home 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i3 (5th Gen) 5005U / 2 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 5400 rpm
Optical Drive
DVD-Writer
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare
Audio & Video
Graphics Processor
Camera
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Layout
Communications
Wireless
Network Interface
10/100 Ethernet
4-cell Lithium Ion
32 Wh
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Administrator password, hard drive password, power-on password
Power adapter
RoHS
Localization
2.3 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
CFFC C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
CFFC C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
