The Lenovo 700-15ISK is a laptop notebook built for performance, with standard voltage processor, Nvidia GTX950 graphics, Full HD display and DDR4 memory. Its optional JBL speakers and backlit keyboard provide unparalleled multimedia performance.
Powerful processor
The blazing fast, feature-packed processor with built-in security is ready to take your productivity, creativity, and 3D gaming to another level. What's more, by enabling the exciting features, processor empowers you to unleash your imagination and explore the possibilities. -
Discrete graphics
When you've got discrete graphics card, you know that an extreme graphics experience awaits. So whether it's enhanced visuals for work or a truly vivid gaming/video experience for fun, the Ideapad 700 sure delivers. -
Crisp 15.6" Full HD display
The Ideapad 700 doesn't compromise on display resolution with its 15.6" Full HD (1920 x 1080) display. Everything appears brighter, sharper, and more vivid - from games and video chats to movies and photos. -
Light, and portable
Thin and lightweight, the Ideapad 700 is extremely portable - enabling you to stay connected and be entertained wherever life takes you. -
Supercharged audio
Combining the power and nuance of the cinema with the thrill of live performance, Dolby Home Theater gives you the full-impact of surround sound - anywhere.
- Lenovo IdeaPad 700-15ISK - 15.6" - Intel Core i7 - 6700HQ - 16 GB RAM - 128 GB SSD + 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 16 GB DDR4
- Storage
- 128 GB SSD + 1 TB HDD / 5400 rpm
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 950M / Intel HD Graphics 530
- Video Memory
- 4 GB
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 3-cell - up to 4 hours
- White
- 38.4 cm x 26.5 cm x 2.27 cm
- 2.3 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Integrated memory controller
- RAM
- 16 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 128 GB SSD M.2 PCIe
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 5400 rpm
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB
- Camera
- Yes - 720p
- Resolution
- 1 Megapixel
- Sound
- Stereo speakers, subwoofer, two microphones
- High Definition Audio, Dolby Home Theater
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 3-cell lithium polymer
- Capacity
- 45 Wh
- Run Time
- Up to 4 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 135 Watt, 20 V, 6.75 A
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- White
- Case Material
- Polycarbonate ABS
- Administrator password, hard drive password, power-on password
- Theft/Intrusion Protection
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 2.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
