Lenovo 2.4 TB Hot Swap 2.5'' SAS 12Gb/s 10000 rpm
Quicklinx: FQSLWS00 Mfr#: 7XB7A00069
£259.54 ex VAT
£311.44 inc VAT
The Lenovo 2.5" hot-swap hard drive is a storage solution designed to meet the needs of demanding data environments. With a generous 2.4 TB capacity, it offers plenty of space for large datasets, while the fast 1.2 GBps data transfer rate and 10,000 rpm spindle speed ensure rapid access to stored information. This hard drive also supports Serial Attached SCSI 3 interface, providing reliable connectivity and data transfer. Its advanced format 512n feature further enhances data integrity, making it a smart choice for businesses looking for robust storage options.
  • Enhanced capacity
    Boasting a substantial 2.4 TB capacity, this hard drive offers ample space for storing large volumes of data, making it suitable for high-demand storage requirements.
  • High-speed performance
    With a data transfer rate of 1.2 GBps and a spindle speed of 10,000 rpm, this hard drive ensures swift access to stored information, significantly enhancing data processing efficiency.
  • Robust design
    Designed for hot-swap support and featuring an advanced format 512n, this 2.5" Serial Attached SCSI 3 hard drive is engineered for durability and seamless integration into existing server setups.
Lenovo - hard drive - 2.4 TB - SAS 12Gb/s
Hard drive - hot-swap
2.4 TB
2.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
10000 rpm
Advanced format 512n
ThinkAgile HX33XX Appliance; HX33XX Certified Node; HX3520-G Appliance; HX3721 Certified Node; HX7531 Certified Node; HX75XX Appliance; HX7820 Appliance; HX7821 Certified Node; MX3330-H Appliance; MX3331-H Certified Node; ThinkAgile VX 1SE Certified Node; 2U Certified Node; 2U4N Certified Node; ThinkAgile VX Certified Node 7Y94; ThinkAgile VX1320 Appliance; VX3331; VX33XX Appliance; VX3520-G Appliance; VX3530-G Appliance; VX3575-G Integrated System; VX3720 Appliance; VX5575 Integrated System; VX7575 Integrated System; VX75XX Appliance; VX75XX Certified Node; ThinkSystem SR250; SR530; SR550; SR570; SR590; SR630 V2; SR645; SR650 V2; SR665; SR850; SR850 V2; SR860; SR860 V2; ST250; ST650 V2
2.4 TB
2.5"
SAS 12Gb/s
Performance
Drive Transfer Rate
1.2 GBps (external)
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5"
Lenovo ThinkAgile HX3321 Certified Node 7Y89 (2.5") , Lenovo ThinkAgile HX3330 Appliance 7Z85 (2.5") , Lenovo ThinkAgile HX3331 Certified Node 7D52 (2.5") , Lenovo ThinkAgile HX3375 Appliance 7D5U (2.5") , Lenovo ThinkAgile HX3376 Certified Node 7D5U (2.5") , Lenovo ThinkAgile HX3520-G Appliance (2.5") , Lenovo ThinkAgile HX3721 Certified Node 7Y88 (2.5") , Lenovo ThinkAgile HX7520 Appliance 7X84 (2.5") , Lenovo ThinkAgile HX7530 Appliance 7Z82 (2.5") , Lenovo ThinkAgile HX7531 Certified Node 7Z84 (2.5") , Lenovo ThinkAgile HX7820 Appliance 7Y95 (2.5") , Lenovo ThinkAgile HX7821 Certified Node 7Y96 (2.5") , Lenovo ThinkAgile MX3330-H Appliance 7D19 (2.5") , Lenovo ThinkAgile MX3331-H Certified Node 7D67 (2.5") , Lenovo ThinkAgile VX 1SE Certified Node 7Z58 (2.5") , Lenovo ThinkAgile VX 2U4N Certified Node (2.5") , Lenovo ThinkAgile VX Certified Node 7Y94 (2.5") , Lenovo ThinkAgile VX1320 Appliance 7Z58 (2.5") , Lenovo ThinkAgile VX3320 Appliance 7Y93 (2.5") , Lenovo ThinkAgile VX3330 Appliance 7Z62 (2.5") , Lenovo ThinkAgile VX3331 7Z62 (2.5") , Lenovo ThinkAgile VX3520-G Appliance 7Y94 (2.5") , Lenovo ThinkAgile VX3530-G Appliance 7Z63 (2.5") , Lenovo ThinkAgile VX3575-G Integrated System 7D43 (2.5") , Lenovo ThinkAgile VX3720 Appliance 7Y92 (2.5") , Lenovo ThinkAgile VX5575 Integrated System 7D43 (2.5") , Lenovo ThinkAgile VX7520 Appliance 7Y94 (2.5") , Lenovo ThinkAgile VX7530 Appliance 7Z63 (2.5") , Lenovo ThinkAgile VX7531 Certified Node 7Z63 (2.5") , Lenovo ThinkAgile VX7575 Integrated System 7D43 (2.5") , Lenovo ThinkAgile VX7576 Certified Node 7D43 (2.5") , Lenovo ThinkSystem SR250 (2.5") , Lenovo ThinkSystem SR630 V2 7Z71 , Lenovo ThinkSystem SR645 7D2X , Lenovo ThinkSystem SR650 V2 7D15 (2.5"), 7Z73 , Lenovo ThinkSystem SR665 7D2V, 7D2W (2.5") , Lenovo ThinkSystem SR850 V2 7D32 (2.5") , Lenovo ThinkSystem SR860 V2 7Z60 (2.5") , Lenovo ThinkSystem ST250 (2.5") , Lenovo ThinkSystem ST650 V2 7Z74, 7Z75 (2.5")
Brand: Lenovo
