Brand
Lenovo 1TB ThinkPad USB 3.0 Secure 2.5" Portable Hard Drive
Quicklinx: 8P5WWS00 Mfr#: 0A65621
Form Factor: 2.5"
Capacity: 1TB
Interface: SuperSpeed USB
More than 50 in stock
£181.34 ex VAT
£217.60 inc VAT
Optimized for safeguarding essential data while on-the-go, the ThinkPad USB 3.0 1TB Secure Hard Drive offers high-level 256-bit Advanced Encryption Standard (AES) security within a slim, lightweight, self-powered, easy-to-use design.- Connectivity via either USB 2.0 or USB 3.0 (2) interface
  • Compact size
  • No requirement for an ac power adapter
  • Driverless operation under Microsoft Windows 7, Windows XP and Vista
  • All stored data is fully encrypted using the AES 256-bit security encryption algorithm
  • Real-time encryption with no read/write speed impact
  • Shock-mounted 1TB 5400 rpm hard drive capacity
  • Built-in USB 3.0 cable with an integral storage slot
  • Integrated high quality metal dome switch keypad for entering an 8 to 16 digit password for 1 user ID and 1 administrator ID
  • USB Y extension cable to ensure adequate power
  • Attractive protective carrying case
  • Non-skid anti-vibration pads
  • High quality ThinkPad soft touch paint
  • Multi-colored LED device status indicator
The ThinkPad USB 3.0 1TB Secure Hard Drive option also enables
  • Easy and secure storage expansion
  • No software installation and no power adapter required for operation
  • Built-in administrative password management
  • Simple file backup
Lenovo ThinkPad USB 3.0 Secure - hard drive - 1 TB - USB 3.0 - CRU
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Shock resistant, built-in keypad, password authentication, 256-bit AES
Power Source
USB bus
8.69 cm x 12.203 cm x 1.925 cm
216 g
Pricing Type
Customer-replaceable Unit (CRU)
3-year warranty
100e Chromebook (2nd Gen) MTK.2; 100e Chromebook Gen 3; 14e Chromebook Gen 2; 14w Gen 2; 500e Chromebook Gen 3; IdeaPad 3 15IGL05; 3 15IML05; S145-14; IdeaPad Slim 7 14ARE05; ThinkCentre M60; M70a Gen 2; M70q Gen 2; M70s Gen 2; M75; M75q Gen 2; M75s Gen 2; M75t Gen 2; M80; M90; M90a Gen 2; M90q Gen 2; M90s Gen 2; M90t Gen 2; ThinkEdge SE30; SE50; ThinkPad E14 Gen 3; E15 Gen 3; L13 Gen 2; L13 Yoga Gen 2; L14 Gen 2; L15 Gen 2; P1 Gen 4; P14s Gen 2; P15s Gen 2; P15v Gen 2; T14 Gen 2; T14s Gen 2; T15 Gen 2; T15p Gen 2; X1 Carbon Gen 9; X1 Extreme Gen 4; X1 Titanium Yoga Gen 1; X13 Gen 2; X13 Yoga Gen 2; ThinkStation P340; P350; V14 IGL; V330-20ICB AIO; V50a-24IMB AIO; V50s-07; V50t Gen 2-13
1 TB
USB 3.0
8.69 cm
12.203 cm
1.925 cm
216 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Max Data Transfer Rate
75 MB/s
Data Transfer Rate Details
USB 3.0 (read): 75 MB/s , USB 3.0 (write): 55 MB/s , USB 2.0 (read): 33 MB/s , USB 2.0 (write): 25 MB/s
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Carrying case
1 x USB cable - integrated , 1 x USB extension cable - external
UL, VCCI, C-Tick, BSMI, cUL, FCC, ICES
Pricing Type
Limited warranty - 3 years
5 °C
55 °C
5 - 95%
Lenovo 100e Chromebook (2nd Gen) MTK.2 82Q3 , Lenovo 100e Chromebook Gen 3 82J7, 82J8 , Lenovo 14e Chromebook Gen 2 82M1 , Lenovo 14w Gen 2 82N8, 82N9 , Lenovo 500e Chromebook Gen 3 82JB, 82JC , Lenovo IdeaPad 3 15IGL05 82BU , Lenovo IdeaPad 3 15IML05 82BS , Lenovo IdeaPad S145-14IKB 81VB , Lenovo IdeaPad Slim 7 14ARE05 82A5 , Lenovo ThinkCentre M60e 11LU, 11LV , Lenovo ThinkCentre M70a Gen 2 11K3 , Lenovo ThinkCentre M70q Gen 2 11MY, 11N0, 11N4 , Lenovo ThinkCentre M70s Gen 2 11M6 , Lenovo ThinkCentre M75n 11BU, 11BV , Lenovo ThinkCentre M75q Gen 2 11JN, 11JQ , Lenovo ThinkCentre M75s Gen 2 11R7, 11R8, 11R9, 11W1, 11W4 , Lenovo ThinkCentre M75t Gen 2 11KE, 11RB, 11RC, 11RD, 11W6 , Lenovo ThinkCentre M80q 11EG, 11Q9 , Lenovo ThinkCentre M90a Gen 2 11JY , Lenovo ThinkCentre M90q 11DH, 11DK, 11F0 , Lenovo ThinkCentre M90q Gen 2 11MQ, 11MR, 11MV , Lenovo ThinkCentre M90s Gen 2 11L6 , Lenovo ThinkCentre M90t Gen 2 11L4 , Lenovo ThinkEdge SE30 11NA, 11NB, 11NC, 11NJ , Lenovo ThinkEdge SE50 11RJ , Lenovo ThinkPad E14 Gen 3 20Y7, 20YD , Lenovo ThinkPad E15 Gen 3 20YG , Lenovo ThinkPad L13 Gen 2 21AB, 21AC , Lenovo ThinkPad L13 Yoga Gen 2 21AD, 21AE , Lenovo ThinkPad L14 Gen 2 20X5, 20X6 , Lenovo ThinkPad L15 Gen 2 20X7, 20X8 , Lenovo ThinkPad P1 Gen 4 20Y3, 20Y4 , Lenovo ThinkPad P14s Gen 2 20VY, 21A0, 21A1 , Lenovo ThinkPad P15s Gen 2 20W7 , Lenovo ThinkPad P15v Gen 2 21A9, 21AA , Lenovo ThinkPad T14 Gen 2 20XK, 20XL , Lenovo ThinkPad T14s Gen 2 20XF, 20XG , Lenovo ThinkPad T15 Gen 2 20W5 , Lenovo ThinkPad T15p Gen 2 21A8 , Lenovo ThinkPad X1 Extreme Gen 4 20Y5, 20Y6 , Lenovo ThinkPad X1 Titanium Yoga Gen 1 20QB , Lenovo ThinkPad X13 Gen 2 20XH, 20XJ , Lenovo ThinkPad X13 Yoga Gen 2 20W8, 20W9 , Lenovo ThinkStation P340 30DU , Lenovo ThinkStation P350 30E3, 30E4, 30E5, 30E6 , Lenovo V14 IGL 82C2 , Lenovo V330-20ICB AIO , Lenovo V50a-24IMB AIO 11FK , Lenovo V50s-07IMB 11HA , Lenovo V50t Gen 2-13IOB 11QE
Form Factor: 2.5"
Capacity: 1TB
Brand: Lenovo
Stock Status: In stock
